Hi guys! So here's my trouble, i purchased the S-H10SO14T-HTC Akrapovic. Got a 2014 CBR1000RR (Russian market), but that piece of junk doesn't fit! First, bike has much slimmer exhaust outlet for that slipon, slipon would fit 60mm, i think. Why the bike's exhaust has so small outlet? I doublechecked the fitment before purchase! Second, slipon has no o2 sensor... Questions: 1) Returning the slipon is not an option, so i've got an idea of buying a 60 mm header. Will it fit my bike? 2) Saw in one of the posts a "sleeve" for my exhaust and slipon, is it avaliable for sale online? Thanks in advance for answers!
Your Russian model bike must have the non Eu headers which are 50mm. You need the GB or Eu headers which are 60mm. These have the cat and the O2 sensor fitted. This is what I have on my GB bike with the Akra.
Thanks, iang27! I found the 60mm header, will it fit the bike? Will be unfun, if i buy this one and it won't fit )) So 50mm has the o2 and valve on the stock silencer, the 60mm has o2 on the header and the valve on the silencer, right?
Yes the 60mm headers has the hole for the O2 sensor before the cat, the pipe then has about a 4/5" cat then the 60mm outlet. The later headers also have a link between 2 and 3 cylinder. As far as I know they fit straight on, after all your bike is the same apart from the exhaust.
Have to say, it's a very messed up "improvement" from Honda.... Will grab the 60mm and try it Thanks a lot for help and pics!!
