Engine light on
Discussion in 'General 1000RR Discussion' started by Neil lond, Aug 17, 2016.
  1. Neil lond
    Neil lond New Member
    hi. I have just fitted a new exhaust to my 2010 fireblade, i also fitted a o2 eliminator but the engine management light is staying on. As anyone got any ideas and does it cause problems running it like this. Cheers.
    Neil
  2. blake7
    blake7 Active Member
    is it on or flashing?
  3. Neil lond
    Hi. It just stays on.
  4. blake7
    have you still got the exhaust servo connected?
  5. Neil lond
    No i have disconnected
  6. blake7
    you have fitted a servo eliminator also then?
  7. Neil lond
    No not fitted servo eliminator just the o2 eliminator
  8. blake7
    you need to plug the servo back in and then make sure the pully is in the right place (google it if unsure). No cables needed obv, but it needs plugging back in until you get a servo eliminator.
  9. Neil lond
  10. blake7
    You can leave the servo in place, or if you want to make space or lose weight then fit a servo eliminator. The wheel on the servo needs to be set in the right position. Back in the same place it was before you touched it to remove the cables.
  11. Neil lond
    Ok thanks for the info. I will look into that. Cheers
    Neil
  12. Neil lond
    Set there servo to the right position and light has gone off :).. Thanks for the help. Forums are the best:)
  13. blake7
    Glad you got it sorted and yep, forums are great places. This one in particular :)
