GRRRRRRRRR FOOKING TYRES
Discussion in 'General 1000RR Discussion' started by dave the rave, Oct 22, 2016.
  1. dave the rave
    dave the rave Active Member
    just put brand new pilot road 4 tyres on got a puncher in rear less than 30 miles on it shit
  2. raphael
    feel your pain mate as done the same, can get it plugged and use it as normal though
  3. dave the rave
    No can't even plug it right between tread
  4. stujacks
    stujacks Active Member
    Hi
    Why can't you plug it cuz it's between the tread.
    Cheers Stu
  5. Great Guy
    Great Guy Well-Known Member
    I have just put a pair of 2014 wheels on my 09 blade. Spent ages changing the cush drive and newish tyres over. Went out today and guess what, a rusty broken washer right in the center of the rear. I will get it plugged next week. It is also in the center of the tread. Road pilot 2.
  6. dave the rave
    Took it to motorcycle shop today they said no chance
  7. sps170373
    I've had michelins repaired before and last one had a screw between the tread and was repaired no problem, phone around as sounds like your bike shop just wants to sell you another tyre! Michelin quote on their site you can repair them a couple of times
  8. dave the rave
    cheers I'll look into it
  9. Wozza
    Wozza Elite Member
    Just buy a new rear I would not want a plugged tyre ......not worth it blowing at speed would be at the back of my mind.....agree it is harsh as more money but ....
  10. dave the rave
    That's in the back of my mind mate wouldn't forgive myself leaving kids with no dad might just bight the bullet and pay the £120
  11. Wozza
    Wozza Elite Member
    Yes mate ...I had this happen on new car tyre .....it really does miff u off ,,,back in the uk my next door neighbour had his kitchen ripped out skip on the drive nails, screws everywhere wasn't happy 2 puncture repairs and one new tyre , he said prove it was off his drive but it was obvious...wish I hadn't bother brushing them up but give me a right complex when I had the bike out....
  12. dave the rave
    I'll have to buy a tyre my son goes on the back it's a bitter pill to swallow though
  13. Blade runner 1
    Blade runner 1 Elite Member
    A lot of dealers, garages etc won't fix a motorcycle puncture. There is to many variables and they wouldn't want to be liable if it failed.I fit my own tyres and have fixed several motorcycle punctures over the years using mushroom type plugs without a problem. As long as the area to be repaired is not excessively damaged and is not too far from the centre of the tyre I wouldn't have a problem. Different manufacturers have different views on the subject. At the end of the day it's up to you if you want ride on a repaired tyre.
  14. dave the rave
    Don't think I can risk it
  15. bonjo
    punctures in general can be repaired as long as it is within a certain area of the tyre and not too big for the mushroom. I know some garages are not interested but they give all the wrong reasons to get you to buy a new tyre.
    If you have the money, then do get a new tyre to give yourself the peace of mind you are after. Hope your next tyre lasts much much longer:)
  16. dave the rave
    Just had it repaired lets hope its ok
  17. exuptoy
    exuptoy Elite Member
    I repaired my M7RR rear after only 1 month with one of those rep+air (I think it was anyway) mushroom plugs. Not even lost any pressure since the repair.
  18. bonjo
  19. travellingkiwi
    travellingkiwi Active Member
    Course you can. Lets face it, it's no more likely to blow after the repair than before. Leak air past the plug if it's not done properly, maybe. But that's going to be slow.
  20. travellingkiwi
    You could also try 'slime'.
    or there is another one some dealers sell (Chiswick Honda had it a couple of weeks ago when I was in there. Punctureseal? (http://www.punctureseal.com/jugs.html). Used to come in a big bottle (Their website says it's only available in jugs now)
    Works like a charm. You chuck it in the tyre when it's new (or not so new) and it just seals when/if you get a puncture. When I was riding on the Colnbrook bypass daily, I used to use it always. It saved me about a puncture a week.
