Gilles shift support fitting question
Discussion in 'General 1000RR Discussion' started by Danny555, Nov 22, 2016.
  1. Danny555
    Danny555 New Member
    I've fitted a shift support to my blade.
    The question is do you git rid of the retaining clamp and just fit the support as that must act as the clamp too I'm guessing
    I've attached photos to show you what I mean
    That's what I removed
    So do I keep that on and put the support over it or just leave it off?
    That's it fitted without the little clamp.
    Thanks
  2. ColinBR
    Yea get rid.
  3. Dave dunlop
    Dave dunlop Elite Member
    Yep bang on fella... no clamp required
  4. Danny555
    Danny555 New Member
    That's great cheers guys
    • Dislike Dislike x 1
  5. Punisher5964
    Punisher5964 Active Member
    I only found out about these today, do they make a big difference? I'm guessing it just supports the shaft so when you change it feels more sturdy as there is no flex in the selector?
  6. mikegml
    mikegml Active Member
    Feels a bit more slick with it, not a big difference.
  7. Punisher5964
    Worth it though?
  8. mikegml
    If you've got £50 spare and feel like pimping your bike a bit then yeah, it's a quick easy job, otherwise probably no.
    If someone fitted one to your bike without you knowing you'd be pushed to notice. Fit it yourself and you'd notice it's a tad more positive.
  9. Dave dunlop
    Looks identical to the Gilles one and cheaper! I noticed a difference once mine was fitted, definitely more positive shift!
  10. mikegml
    This is the Gilles one below which I've got fitted. The one in the link is obviously very different. Surely the Gilles one with two fixing points has to be better than the single fixing point one?
  11. dansp1
    dansp1 Active Member
    yours is for the older model blade
  12. Dave dunlop
    Correct.... the later bike only has one fixing bolt that's in the same place as the original support mount bolt. Plenty sturdy enough and has no movement once it's bolted down.
