warped disc
Discussion in 'Maintenance' started by newruc, Dec 11, 2016.
  1. newruc
    newruc New Member
    hi gents / lasses.
    seem to have got a braking vibration on my RR6.
    cleaned rivets time and again , makes no difference
    so got to be a warped disc.
    whats the best to replace with (don,t say brembo)
    not a rich man.
    does any later year disc fit ?
    thanks
    mick
  2. Tonic
    Tonic Active Member
    Had this on a CBR 600, then someone gave me the following advice, so may be worth a try.
    Put a nut and bolt through the rivets and make sure their loose, clean with electrical solvent cleaner. Do all the rivets in both discs.
    Then, remove the calipers.
    Put a DTI on the disc and look for the high and low spots, tap the associated rivets with the shaft of the hammer until the become true.
    I didn't believe it would work, but it worked for me.
  3. newruc
    newruc New Member
    thanks Tonic,
    i will give it a try
    mick
  4. Kentblade
    Maidstone Motoliner do a great job in truing warped discs
  5. Scott
    Scott Active Member
    This
  6. RazorBlade
    RazorBlade Member
    Had a mates 675 that he swore black and blue had a warped disk and that he had cleaned buttons. Screwed driver through then with some brake cleaner and a few taps. No more "warped" disk.
  7. blake7
    blake7 Active Member
    £78 in total to post discs to motoliner
  8. blake7
    There is a place in Notts also depending on where you are, charged me £25 a disc from memory.
