Thoughts on using an optimiser!
Discussion in 'Maintenance' started by ufoxed, Jan 8, 2017.
  1. ufoxed
    ufoxed Active Member
    Hi Guys
    I have just tried starting my fireblade and the battery is a bit down so wouldn't start so today I purchased an optimiser to help on this front but I have a few question on your experience of using them as I am know you guys know your stuff... Firstly is it better to re-charge on or off the bike as I really don't fancy having a battery and charger in the kitchen all winter-no where else to put it unless I keep it on the bike.
    If I keep it plugged in and the battery on the bike all winter I will have air flow and ventilation problems as I keep the bike cover on and a blanket over that to keep moister out as I keep it in a shed. This is my preferred option and I will also have to get power to the shed.
    I saw that Oxford do a out door solar panel that is an optimiser but cannot charge just maintain a battery has any one used one? And are they any good?
    Thanks for your time guys.
    Ufoxed
  2. tony lomas
    tony lomas Member
    Hi I use my optimate all the time when I'm not riding it's wired to my battery never had a problem over winter .I also keep her covered up in my bike garage .
  3. Wozza
    Wozza Elite Member
    Hi mine is plugged into one all the time and no issue I have the lead by the rear footpegs so don't have to take out and then covered although in internal garage ,,,I think yours will be alright in a shed as long as you could get a weather proof extension lead to it and then cover as you say above
  4. Blade048
    Blade048 Active Member
    As above, I have mine connected up to the bike and keep it plugged in all the time when not in use and no problems.
  5. Muffking
    Same here. I only have 1 charger and 2 bikes, but alternate it between both bikes in the garage usually a week at a time.
  6. ufoxed
    ok guys thanks for taking time to reply ...I will leave it connected to the bike in the shed which is what I wanted to do any way so thanks...
    Ufoxed
