r&g radiator guard
Discussion in 'Mods, Upgrades, Accessories and Products' started by hessel, Feb 9, 2017.
  1. 1000rrboyjay
    1000rrboyjay Active Member
    I have one too and woukd definitely recommend. Easy fit too
  2. Jez
    I have fitted a fender extender I took my time and used professional glue, I heated both up and and hot glued it on. they were both clamped tight all round, I could not face bolting or riveting, also they did not fit each other very well. so with the heat and clamps both fit together well. when it is on you hardly see it DSCN0618.JPG
    • Friendly Friendly x 1
  3. hitch
    hitch Elite Member
    I really like this. Nice work.
  4. Squasham
    Squasham New Member
    That grill looks smart, shame i didn't read this before I order and fitted my R&G grill.
    They are easy to fit and the sense of satisfaction when the grill perfectly fits in the space :)
    #24 Squasham, Feb 26, 2017
  5. Phil_M
    Phil_M Active Member
    Ordered one of these after reading your post.
    Ordered on Sunday evening and it arrived in the post today - looks to be a nice piece of kit and fantastic service!
  6. Singh1000RR
    Singh1000RR Active Member
    Just as a warning to all - my friends '15 plate SP was holed on a ride out. Local dealer wants £1000 :eek::eek::eek: to replace and fit new one. You have been warned people!!
    Cheapest one he has found is £750 for second hand one.
  7. Ian E
    Ian E Active Member
  8. Lozzy
    You'd think that considering the relatively cheap cost of a radiator guard...they'd put one on as standard o_O
  9. hessel
    hessel Member
    he might be searching a bit better then...
    they cost just shy of 750 new....thats euros (677 pound)
    still alot and therefore i fitted a quard..:)
    http://www.lingshondaparts.com/hond...518.png&block_03=984&block_04=lp&block_05=hmc
  10. fisher
    fisher Active Member
    Tried to order one myself today, Dan came straight back to me an said he's on Holidays at the moment, so I'll have to wait a week till he returns to work.
  11. sp1n99
    sp1n99 Active Member
    Has he tried someone like GMX Radiators for a repair or re-core?
  12. Singh1000RR
    I'll pass on your suggestions to him when I see him.
    This thread got me doing some investigation to see how much rad guards cost and both EvoTech and R&H are doing them for approx. £75 (shipped).
    I also found that you can buy a 16" x 12" mesh guard and fit it to your bike manually. Anyone done this??
    http://www.rg-racing.com/browsebike/Honda/CBR1000RR_Fireblade/2014/RADUM01/
  13. Blade runner 1
    Blade runner 1 Elite Member
    My brother and a mate both got holes in there radiators last year and had them repaired, cost about £40 if I remember correctly. Proper job, pressure tested etc. They then promptly fitted R&G radiator guards as did I.
  14. Ian63
    Ian63 Active Member
    I'm not sure whether it's me being un-tech savvy on my samsung phone but when I tried to access the racing radiator guards site through FB it automatically directed me to eBay where it said the 'Shop seller was currently away'. Any ideas?
  15. fisher
    He's on Holiday for a week mate, his shop will reopen then
  16. Ian63
    Ian63 Active Member
    Thanks
  17. fisher
    Just a heads up, he's back trading on EBay, just ordered mine, £30 delivered.
  18. Ian63
    Ian63 Active Member
    Many thanks Fisher - just ordered mine
  19. Jandy
    Jandy Active Member
    Just ordered myself an HRC one off Dan are they pretty easy to fit ? ;)
  20. RRG
    RRG New Member
    Dan from Racing Radiator Guards here.
    Thanks for the kind words, thought I would pop up and say hello.
    To answer fitting question:
    Might help to remove right side fairing as you look at the bike just to get the purchase.
    I did a video for fitting a long time ago now but subsequently made a vid covering them all both are here:
    To fit:
    1.) The left side slots in to the recess at the side
    2.) Press your hand against the radiator in the middle so its flush
    3.) The opposing right side should over lap 1mm or so (you may need to move guard up and down to get this perfect)
    4.) "Clip" the right side into the recess
    5.) The mesh should be pretty much flush with the rad across the width.
    When fitted correctly it needs minimal securing on the blade as it cant pop out easily, it cant move down or up it pretty much locked in place..
    You can pull the guard closer to the rad there are two methods, my favorite listed first
    Option 2
    Cheers Dan
