Brembo Master Cylinder Reservoir Bracket
Discussion in 'Wanted' started by TheMickster, Mar 1, 2017.
  1. TheMickster
    TheMickster Active Member
    Hi
    Has anyone got a spare Brembo master cylinder reservoir mounting bracket, or know anyone who just sells the bracket?
    The metal bracket in the picture below:
    My current one snapped :(.
    Mike
  2. tuktuk
    tuktuk Elite Member
    Search for butterfly bracket i think they are called. Basically same thing but can be shaped however you need it.
  3. tuktuk
    tuktuk Elite Member
  4. red5
    red5 Well-Known Member
    Why not just make one out of a bit of aluminium bar.
  5. TheMickster
    I think with the range of tools at my disposal and my fabrication skills it would probably end up looking like something you might find on a 19th Century ocean liner (i.e big, heavy and not very elegant). :)
  6. TheMickster
    Cheers mate, not near my bike at the mo so any idea what size holes you need at either end for the brembo master cylinder clamp end and the reservoir end?
  7. tuktuk
    tuktuk Elite Member
    I have no idea mate as my rcs hasnt arrived as of yet. Fair few on here have them who may be able to tell you.
  8. sps170373
    The clamp screws/bolts are 6mm diameter from memory for the clamp on the master cylinder! I used one of the ladybird brackets but drilled one hole to 8mm and bolted to the top clamp of the forks
  9. CBR-Pete
    CBR-Pete Active Member
  10. Mr OCD
    Mr OCD Well-Known Member
