I have a question about the Bazzaz units. I've always gone with PC's but my new track bike has a Bazzaz unit with 2 maps and traction control. When I got it I noticed that the o2 sensor was still attached and in the exhaust. It doesn't have auto tune so I'm not sure if it should be there or not. I know with PC5 you take the o2 sensor out so it doesn't muck up the map on it. I assumed it would be for the same on the Bazzaz as aren't they essentially the same thing. Who runs Bazzaz, and do you still have the o2 sensor attached? Thanks Ben
Yeah it is. Or at least it was as I've taken it out for now. Just trying to work out if they should be run with the sensor in or not.
You normally remove them like you said. Have you put an eliminator on then if you have removed the sensor to stop the light coming on? Has it had the pair removal done also?
Yeah I put an eliminator on as well as the bung in the link pipe. Pair mod has been done also. I leave it off I think. It's going to get mapped fairly soon anyway at Track Electronics so I'm sure they will tell me if it should be there or not. Cheers
