Brembo calipers from SP blade
Discussion in 'Parts, Accessories & Clothing' started by stupot, Apr 19, 2017.
  1. stupot
    stupot Active Member
    Sp Brembo M4 calipers
    Excellent condition
    With nearly new sintered pads
    £475 Ono delivered
    Still on the bike and will be removing at the weekend
    [​IMG][​IMG]
  2. Gts2pro
    Gts2pro Active Member
    Hi what year As I have a 2013 fireblade 1000rr. How come your selling them ?
    Thanks
  3. stupot
    I'm putting the bike back to standard
    Mine is a 13 plate aswell
  4. Gts2pro
    Oh right. Ok. Thought they came with the sp model.
    They do look nice thou. What the shipping options ?
  5. stupot
    I can remove them the weekend
    Post Monday then you'll have them by Wednesday
  6. sandman3791
    sandman3791 Active Member
    Did you just replace the calipers or do you need to replace anything else with them?
  7. stupot
    They bolt straight on
    You don't need the ally spacers which are on the 08 to 16 fork bottoms. OE discs and lines fit
  8. kingy3
    kingy3 Active Member
    Are they the 34mm piston or 32 ones
  9. stupot
    32 I'd imagine as they are from the sp
  10. Untold65
    Untold65 New Member
    Will they fit on 65 plate if so txt me please if am allowed to post fone number ?
  11. stupot
    These are now sold
  12. TW4T50N
    TW4T50N Active Member
    Hi @stupot, fitting a set of these to my bike and was wondering if you bothered with the dowels/spacers from the newer bike to get them seated and fitted properly? If not that's great, I have everything I need to get them bolted on :)
  13. stupot
    My cousin spun me up 4 on a lathe to my measurements.
    They were a bit loose.
    If you get someone to pull the brake lever when you tighten the caliper bolts they will line up ok.
    Or abc if I can find them I can send you them if you like.
    Probably on the garage floor somewhere
  14. TW4T50N
    If you could find them that would be f*cking fantastic dude. Let me know what you want for them.
  15. stupot
    If I can find them you can have them. I did sweep the floor yesterday so it's only 50/50 they are here.
    I'll have a look later
  16. TW4T50N
    Thanks man, I appreciate it.
