  1. tuktuk
    tuktuk Elite Member
    Brembos on
    New lines on
    Zero gravity on
    Oil and filter change
  2. Terry Clark
    Terry Clark New Member
    Just been out for a cheeky blast down the Northumberland coast getting used to my new ASV shorty levers love them.[​IMG][​IMG]
    Terry
  3. hitch
    hitch Elite Member
    That is one sweet looking Blade tuktuk.
  4. Hedges
    Hedges Active Member
    Racefit black edition with diffuser and stomp grips fitted and a bloody good clean :) IMG_2371.JPG IMG_2370.JPG
  5. tuktuk
    tuktuk Elite Member
    Thanks mate appreciate it!
    Bought this from a mate who has changed his 08 for a new sp1.
    And had these fitted for James Whitham day at Croft on thursday.
  6. tuktuk
    tuktuk Elite Member
  7. MikeB
    MikeB Active Member
    Removed the rear pegs and hangers.
    Wonderfully easy - just a two bolts from underside, no bits of fairing to come off or anything.
    Also removed those horrible orange reflectors from the sides of the front brake callipers (see my post in the mods section)
    On a matt black 2017 Fireblade
  8. gcon45
    gcon45 Active Member
    Sounds like a man who has past experience of removing the rear pegs on an 08> blade!
  9. Watmon
    Watmon New Member
    Finished fitting my CRC fairing after much faffing, cups of tea (works for Mr Martin) and colourful language!
    '15 SP, CAT C.
    '16 Engine 600 miles
    Braided hoses
    Brembo RCS19
    Akro system
    K&N Air
    PC5 and custom map RJS @ Mallory
    Oz Wheels (rear out for tyre change)
    Carbon frame & swingarm protection
    HRC front & rear subframes
    Cheapo Area22 rearsets (??? watch this space..)
    Other stuff but can't remember right now...
    Now just need to ride it/keep upright IMG_20170624_180832.jpg IMG_20170624_180723.jpg IMG_20170624_180802.jpg IMG_20170624_180832.jpg
  10. si1000repsol
    A blast from the past. @Jamiestrada kindly sent me his modified belly pan which allows the Factory Akrapovic exhaust to fit properly. Top man and saves me a great deal of work.
  11. Jamiestrada
    Not a problem Si hope it complements that amazing bike of yours :) sorry it took so long to send !
  12. tuktuk
    tuktuk Elite Member
    Clutch lever fitted
  13. gcon45
    Just bought a lovely 2007 HRC with only 6300 miles on the clock. So rare to find an RR-7 in this condition with their sort of mileage!
    Added some goodies including Brembo M4 calipers, Brembo 19RCS master cylinder, Goodridge lines, Gilles gear shaft support, Oberon clutch slave cylinder, Hel clutch line, Yoshimura RS-5 carbon exhaust, Renthal sprockets (1 up on rear, 1 down on front), RK gold X-Ring chain, Oxford heated grips, PZR racing gear indicator, R&G bar ends, swingarm bobbins, fork protectors and tail tidy, Honda seat cowl, Cabrini tinted screen, shorty clutch lever and a pair of Pirelli Supercorsa SP V2 tyres (55 rear). IN LOVE!
    #6613 gcon45, Jun 27, 2017
    • Like Like x 6
  14. FirebladeRR
    FirebladeRR Active Member
    @gcon45 impressive list. Fancy adding an ohlins shock on that beauty? Have a spotless one here in the spare room ;)
  15. gcon45
    I would but I would probably get divorced if any more bits arrive! Try me again in a few months if you still have it!
  16. hitch
    hitch Elite Member
  17. sps170373
    Gave the brake bobbins a clean up as weren't moving as freely as they should have been!
  18. levin
    levin Active Member
  19. levin
    levin Active Member
    Fitted a bmc race filter
  20. hitch
    hitch Elite Member
    The guy's name is Jens Neumann - look up member 'Jens' on here.
    I PM'd here and then a follow up email from him sorted the order. His page is entirely in German which I dont speak but he is fluent in English and is very helpful.
    IIRC the kit is €60 odd.
    To fit is a piece of cake, it literally is a plug 'n play. Two 5mm holes in the light caps, grommets in, plug in the kit; cut the connecting wire feed through the grommets, crimp the bullet connector connect up. Done. 30 mins.
