  1. Blade runner 1
    Blade runner 1 Elite Member
    IMG_1790.JPG IMG_1791.JPG IMG_1792.JPG SP seat cowl fitted, lower belly cowl and infill panel painted, excellent match thanks to RS Bike Paints. Rearsets and Gilles gear shift shaft support fitted.
  2. sps170373
    Bought some ohlins fgk203 cartridge inserts
  3. dansp1
    dansp1 Active Member
    did a full brake fluid change on my ABS
  4. sps170373
    Done a bleed on the front brakes
  5. FirebladeRR
    FirebladeRR Active Member
    Hey pal. What weight are you? I just bought a set too and not sure where to start with settings.
  6. sps170373
    Not had them fitted or set up yet! Am 16.5st in full kit
  7. Barstewardsquad
    Fell in love with my bike all over again. Had to pop some kit over to a hospital in Mansfield and they specified between 8am and 10am. I drove over there yesterday with the Frau and it was crap, so today it was bike time. Sunny weather, not many idiots around, and the bike purred along so nicely it was like falling in love all over again.
  8. Spartan Andy
    Spartan Andy Active Member
    Nice One, Did you follow the Honda ABS bleed procedure or used a DIY short cut method?
    :D
  9. dave the rave
    dave the rave Active Member
    Was it hard can you do mine
  10. Openside
    Openside New Member
    Hi mate, how do you find the Zero gravity screen, I've got the MRA but yours looks slightly larger....which is good!
  11. tuktuk
    tuktuk Elite Member
    Really good, i came from the tiny standard screen so it made a massive difference.
    Its bigger than it looks in the picture, some angles it looks a bit out of proportion and others it suits the bike well. Sure does the job though.
  12. Openside
    Openside New Member
    Great, thanks for the info. Think I'll take the plunge and get one
  13. tuktuk
    tuktuk Elite Member
    Just looking through old pics and forund this.
    Ignore the top corner piece which had snapped off. Will give you a better idea of the size.
  14. FirebladeRR
    Which version of the zero gravity is that?
  15. tuktuk
    tuktuk Elite Member
    Corsa.
  16. FirebladeRR
  17. dansp1
    followed the procedure on here, it is not that bad, if i did it again i think a home brew elongated crow foot spanner would be better for the unit behind the headers, two man job though, the worst bit is getting access to everything
  18. Spartan Andy
    Thanks for update. Mines due next year and cannot trust a dealer to carry out the bleed without the standard marks & scratches as a reminder of my visit.
    I will also go down the route of doing the bleed myself.
    Good to see a positive post on the bleed process working out ok for ABS blades. :D
  19. tuktuk
    tuktuk Elite Member
    Feels like ages since ive been on it so had a quick blast up to Kielder to blow the cobwebs off.
  20. TheRamJam
    TheRamJam Well-Known Member
    Finally got round to removing those damn rear pegs.
    2017-07-12 18.21.05.jpg 2017-07-12 18.54.07.jpg 2017-07-12 18.54.13.jpg 2017-07-12 20.02.22.jpg 2017-07-12 20.02.30.jpg
    #6640 TheRamJam, Jul 13, 2017
