Exhaust header nuts issues?
Discussion in 'Maintenance' started by si1000repsol, Aug 3, 2017.
  1. si1000repsol
    Finally fitting the Akrapovic headers. I have seen stories of the the header bolts snapping but is there any issues with the header nuts seizing themselves?
  2. sps170373
    To be honest I'd replace both after my experience when I changed mine over! I had a bolt snap and was a bitch to sort
    I used a stud extractor to pull out the rest and replaced with titanium and used ceramic grease to lube the studs into the head
  3. si1000repsol
    Thanks mate, yes exactly my concerns, I have titanium studs and nuts to fit. Did it snap when undoing the nut?
  4. sps170373
    No stupidly the nuts came off ok and tried to reuse them but snapped when doing back up,
  5. sps170373
  6. si1000repsol
    Well it never quite went according to plan. 6 nuts loosened without an issue. Two came out attaching to the stud! New exhaust is on but will need some alignment.
  7. sps170373
    At least no broken studs! Shouldn't take long to align
  8. KPH
    KPH Active Member
    I recently had the same issue! One of the nuts was firmly attached to the stud and pulled the stud out.
    I bought a replacement and a few spares (nuts & studs).
    What torque should be used for the studs? The nut torque is spec'd in the manual but not the stud.
  9. Tonic
    Tonic Active Member
    I ended up using a slitting wheel on a dremel and splitting the nuts down their length and chiselling them apart, what an absolute PITA. Couple can out with the stubs attached, so replaced them with 8mm threaded rod.
