Shock advice
Discussion in 'General 1000RR Discussion' started by Gravel trap, Feb 25, 2018.
  1. Gravel trap
    Gravel trap Elite Member
    Hi everyone. I'm finding my rr4 a bit low at the back.fronts already dropped a bit to quicken her up. I'm six foot two and fifteen stone. Can anyone recommend a mod or shock from a later blade that I can use to increase ride height?
  2. Firestarter_Phil
    Firestarter_Phil New Member
    Would you look to put in an after market shock? It will definitely give you more adjustment when it comes to both ride height but more importantly rebound and dampening.
    Most people always defaulted to Ohlins (TTX)for replacements, but over the years I have found that the K-Tech DDS is a great alternative. Depending on how hard you ride on both road and track would make the difference between you choosing a DDS Lite or a DDS Pro
    Alternatively Nitro will build a shock to your spec if you know what you need.
    F_P
  3. sulaco
    sulaco Active Member
    Jack up kit?
  4. Gravel trap
    If I won the lotto or managed to sell a kid than yes I'd ohlins . I've Googled but not found a rr4 jack up kit. I imagine hrc did one but again I'm relatively found of the current spawn.
