SP Rear Subframe for sale fits cbr1000rr 08-16
Discussion in 'Parts, Accessories & Clothing' started by vic_ster51, Dec 27, 2018.
  1. vic_ster51
    vic_ster51 Active Member
    For sale i have the SP rear subframe in silver.
    This is the light weight subframe from the SP models of cbr1000rr
    You cannot have passenger pegs fitted with this.
    Item is perfectly straight, mint condition - the bits you see! As fairing etc marks some bits never stop this.
    Comes with top and lower bracket.
    Looks amazing fitted, fits as per standard and fits all years 08-16 abs & non abs
    Quite rare item as only limited numbers of SP's were made
    £150
    #1 vic_ster51, Dec 27, 2018
  2. nozdog
    nozdog Active Member
    Hi Vic can I ask what make of rearsets you have on your fireblade and where you bought them from please?
  3. vic_ster51
    The ones in the picture are gilles fxr rearsets or x factor
    Really nice rearsets can get them anywhere really.
    I dont have them now sold them as i have factory padgetts ones
  4. roboticus
    roboticus Active Member
    whats the padgetts like vic, I have a set somewhere, i'v gilles on at mo, not sure give them a bash
  5. vic_ster51
    Some gilles bit over engineered for my liking hence why i went with the gilles fxr plus they come in silver.
    Then got offered the factory rearsets at great price. Not sure if yours are the same but the fixed position is really nice better than gilles.
    My gear lever didnt leave alot of room for my boot from the sidestand bit to lower it. Had no issues though while riding. You could grind off a cm from it if needed. I did then read about not designed for use with sidestand, but works fine.
  6. nozdog
    Roboticus do you have the gilles fxr rear sets in silver?
    Cheers for the info Vic.
  7. roboticus
  8. nozdog
    Roboticus no reply from you?
  9. roboticus
    sorry kept doing it wrong
    I think there the vcr ones, there on my bike tho, and there black,
    i'v some padgents too, but never tried them, was interested in what there like
  10. vic_ster51
    £175!!!
  11. vic_ster51
    £150 last price!!
  12. Jae
    Jae Active Member
    Are all SP subframes the same? I thought they all had the mounting points for the pillion pegs.
  13. vic_ster51
    None of the sp subframes have holes for pillon pegs. Exhaust hanger only.
    It’s a lightweight frame not designed for passengers
  14. Jae
    Jae Active Member
    I haven't seen them upclose however my mate has an SP frame with sato hooks/pillion pegs fitted. Interesting
  15. vic_ster51
    An SP frame/bike as in from a 14-16 bike? Got a picture?
    Only one side has a thread for the exhaust hanger for racing. Other side has two holes which are bigger anyways even if you wanted to thread it. Could always engineer a threaded insert into it. But the frame designed not to have passengers and much weight so bit risky
  16. Dio'sRR
    Dio'sRR New Member
    Will I be able to retain the ABS unit ?
  17. vic_ster51
    SOLD
    But yeah you could. Frame rails are as standard shape wise etc etc
  18. Mark1
    Mark1 Active Member
    I have got a 2016 sp rear subframe for sale £130, let me know if you are interested
