Folks, I'm thinking of buying a new disc lock for my 2018 SP1 and I want to use it home and away so it will need to fit under the rear cowling (seat) any suggestions would be appreciated. Mike
Oxford Omega.......had mine for about 18 years and is rock solid. Comes with a handy pouch so it doesn't smash around under the seat unit
Looks like it'll do the job......but I'd recommend something flat if you want to store under the seat unit of a '18 '19 SP! Not a lot of room under there!
With apologies that I don't mean to send this thread off track, but that does look surprisingly like one of my butt plugs!
I've been using Oxford patriot disc lock for 11yrs. Stick going strong and it fits nicely under the cowl.
Went with this OXFORD BOSS ALARM 14MM....you need to remove the "U" and lay on top on tool kit before placing yellow body in the middle of cowl (it does fit just).
