Second Batch of Photos for 2013 Fireblade Parts for Sale
Discussion in 'Parts, Accessories & Clothing' started by Dreamblademyth, Apr 1, 2019.
  1. Dreamblademyth
    Dreamblademyth Active Member
    IMG_7969.jpg IMG_7970.jpg IMG_7971.jpg IMG_7841.jpg IMG_7842.jpg IMG_7843.jpg IMG_7846.jpg IMG_7847.jpg IMG_7848.jpg IMG_7960.jpg I am open to sensible offers on the parts- send me a PM. All plastics are pearl sunbeam white apart from the seat cowl.
    1. The tank cowl, Stomp Grips, R&G carbon sliders and HRC tank pad are in very, very good condition with no scratches. There is a rub mark under one of the sliders that cannot at all be seen.
    2. The left hand side panel is in good condition apart from flaking paint in the top inner corner- see photo. There is also a minor paint repair- touch up paint, which can be seen on the top right hand corner of panel. No broken lugs etc..
    3. The right hand panel is in good structural condition with a number of easily visible paint touch up patches (5) in a few areas- see photos. No broken lugs etc..
    4. The carbon belly pan is in good condition but being after market, it needs to be zip tied in place by pulling together the two side panels to lock them to the belly cut out slots. There is also a small plate that has been added to the inside of the belly pan for strength- see photos.
    5. The two levers (bought for £40) are in very good condition and excellent quality.
    6. SOLD: The brake pad pins are titanium and cost £46 new for the set of 5. SOLD
    7. The OEM rear passenger seat cowl is in excellent condition and is NOT sunbeam but it is non-pearl white- see photos of under side of cowl. It was the wrong colour for the buyer so it has been re-listed.
    #1 Dreamblademyth, Apr 1, 2019
  2. Gts2pro
    Gts2pro Active Member
    Hi How much are the pad pins ? I don't need the nut already have the same thing
    cheers
  3. nigelrb
    PM sent.
  4. Dreamblademyth
    PM sent
  5. Dreamblademyth
    PM sent
  6. Lifeofriley
    Lifeofriley New Member
    Price on Chinese levers?
  7. Dreamblademyth
    PM sent
  8. Cadete
    Cadete New Member
    you have the clutch lever bolt? needing one, not sure if there is a nut with it
  9. Dreamblademyth
    No, I do not have one of those.
  10. Stuish
    Stuish Senior Member
    Yes they do come with a nut though.
  11. Dreamblademyth
    The OE nut and bolt is what is reused when replacing the leavers with aftermarket ones.
