Leo Vince GP Pro
Discussion in 'Mods, Upgrades, Accessories and Products' started by Rhysos, May 22, 2011.
  1. flatstickHRC
    flatstickHRC Active Member
    its about £80-£90
  2. Rhysos
    Rhysos Active Member
    Hi,
    Just had my gp pro fitted on my blade and it sounds great. I have gone with the larger of the baffles for now as it is less noisy than without one but a bit more aggressive that the standard baffle. The pick up is also much better than the stock can, not to mention the weight saving and the finish on the can.
    Great product!
  3. LeoVinceSBK
    LeoVinceSBK Active Member
    No probs. Heat shield with mounting kit is £82.75 with the vat OK.
  4. damodici
    damodici Active Member
    Thanks for popping on and clearing things up a little, to be fair to your colleague she actually then sent me some pictures in a 2nd email and each was named accordingly so then it was starting to look like the version I want is going to be ok for track use......however.....just to clear things up once and for all ;)
    Can I use/buy the below exhaust and if I fit the baffle will it pass 98bd?
    I think you've said yes but as they're all named very similar and most of the dealers don't actually seem to know I'd rather Be certain.
    Dong you just love customers ;)
  5. LeoVinceSBK
    Hi,
    GP-PRO's are E approved, and tested with baffle in place, so that's around the 98db mark - but like my colleague said, every bike is different, line up 6 stock fireblades and they'll all sound slightly different and give different db's. We have sold ALL LeoVince slip-on's for track days, race use etc and not had a problem (the only exception like I said is the GP-STYLE which is noisier).
    I reckon you'll prob be OK at 98, but can't give a surefast guarantee. If that's the can you like, then get the can bought and fitted and test the db before going to the circuit. Some guys with mildly tuned blades have experimented with the baffles...one guy welded a small washer across to knock db back a bit..but he did say he had done a lot of engine work and he had a very loud bike!!
  6. Jamz
    Jamz Active Member
    Will it fit okay with this?
  7. TonyBlue
    TonyBlue Active Member
    Have we got any stats on the difference it makes?
  8. LeoVinceSBK
    Hi, the LeoVince carbon shield is tailored to fit any LeoVince slip-on, there is an attachment to the top, the lower front and rear...special stainless brackets are included to mount to LeoVince link pipes. Your link pipe is different! So if you're prepared to modify the brackets and maybe trim the carbon then I'm sure you could make it fit.
  9. Jamz
    Jamz Active Member
    Aww man,
    I hope there isnt too much modification needed...I think it will look lovely on but fabrication isnt my strong point
  10. flatstickHRC
    The front 2 mounting points will definitely fit as top goes to the existing hole and bottom bolts to the sump
    The rear one won't fit as it clamps to the s bend but you could easily make a bracket from the bottom rearward hole of the carbon panel to pick up the bolt hole on the bottom rearward bolt on the left hand side fairing. That is how the yoshi carbon panel is mounted I think.
  11. Jamz
    Jamz Active Member
    Thanks mate, youve put my mind at rest a bit :)
    Nothing worse than wanting to see it on and the bleeder dont fit!
  12. megawatt
    megawatt Well-Known Member
    I can help you with fabrication of brackets mate. Not too far from me if you wanna meet up or meet at Odiham on July 9th. PM ya number for a chat???
  13. Jamz
    Jamz Active Member
    Cool mate, im not going to Odiham due to lack of funds, had alot on this month :(.. i should receive that shield this week so il have more info at the weekend but yea if needed il appreciate your help :)
    Your only 1.5hrs away (ish)
    Im hoping it wont be too much trouble
    #33 Jamz, Jun 20, 2011
  14. megawatt
    Can just turn up as spectator if you PM your reg number for RAF or can meet you part way or come here , we'll measure up and go for a blat. Some great roads down my way!
  15. Jamz
    Jamz Active Member
    cool cool,
    Always up for some new roads to have a blast on, especially if someone else knows them and i dont end up dropping it like i did couple months ago doing a bend i didnt know too fast :\
    Soon as it arrives, were go from there
  16. megawatt
    I'll look forward to it mate. If anybody else needs any bracket or exhaust mods, gimme a shout???
  17. Jamz
    Jamz Active Member
    Sent you a PM mate
    Carl
  18. megawatt
    Cheers mate!
  19. Nutty Tart
    Nutty Tart Well-Known Member
    Sorry for the hijack buuuut what is on at Odiham on the 9th .. and where is Odiham in case I wanna go along myself :eyebrows:
