quick question just put an akrapovic megaphone on my 16 plate it’s got a slight blow on the joint would you leave it to see if it carbons up or would you use a putty if so which is best thx
Neither of the above. I would loosen the slip on ring bracket and the hanger mounting bracket and twist pipe until the joint is perfect.
I've just fitted a scorpion slip on to my new bike and scorpion advise the use of clear silicone on the joint.
I thought exactly the same thing, but the instructions clearly state to use a small amount. I doubt it would be much use further up near the headers but on the slip on it must be fine.
