Brembo rcs is £185 comes with res and tubing etc Akra (the megaphone short style one) 14-16 as 60mm is £375 (comes with baffle) Near mint exhaust PM me number or email ill send more pics & info
Dont understand your message TTX off the shelf shock not the sp spec Ohlins. This way way better. £635
Oh, sorry. Yeah it fits abs and non abs as the hydrologic preload adjuster doesn’t mount on the shock res it’s got the line as in picture so mounts to subframe for example out of the way of the lower battery tray on abs models. If you follow me
