What is this hose?
Discussion in 'Maintenance' started by Odium-fr, Jan 18, 2018.
  1. Odium-fr
    Odium-fr Active Member
    Hi everybody,
    I began to rebuild the bike after my big winter maintenance.
    This afternoon, I replaced the airbox.
    I found a hose connected to the throttle body, which I can't remember where it goes. Actually, I can't remember if it goes somewhere because I don't find any information in the service manual.
    It is made of four hoses connected together and making a new one (in red on the draw).
    Can you help me please?
  2. nigelrb
    Is it open-ended? I suspect it might be the overflow.
  3. Odium-fr
    Ok i found the solution... I should have checked twice before posting...! It is connected under the airbox, at the right side. There is a little "dick" (sorry I couldn't find another word to describe it: D) on which it connects. It is to feed the throttle body with air at idle rpm ;)
  4. mbooth1
    mbooth1 Active Member
    Vac lines connected to MAP SENSOR on RHS. MIKE
  5. Black & White
    Hi @Odium-fr. I've just done a frame swap on my 2010. Give me a shout if you need any further help, while it's still fresh in my mind!
    I was a bit late helping you on your question from yesterday - sorry about that!
    When refitting the fuel tank, I found it definitely helps if you loosen the lower bolts/nuts on the rear subframe, remove the upper ones and allow the seat unit assembly to pivot downwards & rest on the shock unit. This gives you loads more room to connect the fuel line & route the drain tubes.
  6. Odium-fr
    Thanks people,
    But the bike is on its wheel since the message was posted ;)
    I'll make a big service again this winter!
  7. nigelrb
    Yeah, some don't look at dates of messaged posted.
    A guy joins in 2016, makes only one post, and then three years later another new guy welcomes him!!:D:D;)
  8. Odium-fr
    We'll stay with the idea that the will to help the comunity is the most important :)
  9. Spygoat
    Spygoat Well-Known Member
    Il faut pardonner à Monsieur Nigel, il est vieux et sénile. Il est également possible qu'il n'ait pas pris ses médicaments aujourd'hui.
    • Optimistic Optimistic x 1
  10. Odium-fr
    I don't want to be a part of this story anymore :D
    • Funny Funny x 4
  11. Black & White
    @nigelrb: Haha! Guilty as charged, M'lud. I must admit, I just looked at @mbooth1's post date. Is the 2016 guy the one who made his first post after 3 years looking for parts, and then the sarcasm came?
  12. nigelrb
    No comment.:D:D
