Hi All, I've got a 2009 HRC with a MIVV exhaust fitted and it runs lumpy on idle with the baffle out. Am I better getting the ECU flashed and remapped or getting a power commander ? Maps for the PC don't have any specific exhaust in the listing. Cheers
Thank you for the welcome. Would that just be a case of taking out my ECU and sending it to a reputable programmer ? Can you suggest any ? Thanks
Thanks, Do you have the same exhaust ? If I put the baffle in it is a bit better. I prefer it without but the revs hunt a lot at idle and doesn't seem good for the bike the amount it does it by ? Cheers
No, Yoshi R77 no baffle. Sorry, but I am no help with ECU programming, but have had remaps (on other bikes) done through http://www.roadandraceperformance.co.uk/dyno.aspx Plenty of similar establishments around.
