hi, im after some info, ive removed the cat from the headers and welded a bolt in position, the problem I have is I carnt find a sensor eliminator for this model only upto 2016, can anyone advise or help,
Im not too sure for the 17 model but for the previous a Woolich flash has the ability to disable the sensor
I purchased a Servo Buddy servo eliminator for my 2017 blade (its different kit from a 2016 ver). It made a huge difference to low RPM and take off. eg: https://www.revzilla.com/motorcycle/servo-buddy-honda-cbr1000rr-sp-sp2-2017-2018 I am in Australia but I am sure you can get from the UK... Apologies - I just realised you needed to get rid of your o2 sensor... I hope you have an aftermarket ECU. The o2 eliminiator will be the same across models as its only a resistor.
hi, thanks for your info, I don't have a aftermarket ecu I didn't think id need one,if I was to change the full system with no sensor I would need a eliminator, I looked at a arrow full system and was told it comes with an o2 eliminator but when asked if they sold one separate they didn't have any(strange), im a bit at a loss, ive not put the system back on yet so don't no how it will run with the sensor removed, I will keep looking around but if theres anyone else with any advise I would appreciate it, Thanks!!!!
