2016 model ABS light on.
Discussion in 'Maintenance' started by Gainoss, Apr 27, 2020.
  1. Gainoss
    Gainoss New Member
    Hi, does anyone know what would cause this? Do i need to bleed the brakes and can i do this myself?
    Thanks
  2. CharlieR85
    CharlieR85 Elite Member
  3. Slick
    Welcome!
    You need to get the code from the diagnostics first to point you in the right direction.
    If you're handy with spanners and can follow instructions to the letter then the ABS bleed is doable. But before resorting to that get the code and check the basics, it may be as simple as crud on the sensor or sticky pistons.
  4. H0TT@x
    H0TT@x New Member
    this is my first ever post here but i'm only going to say that ALL HONDA CABS SYSTEMS FAIL they only replace them if your under their warranty there are variose figures being spouted around the world as how many riders have been killed this way but its a lot i never gave it creedance unyil it happened to me absolutly no front brakes when i needed them most i will never trust Honda again all weve been is test pilots that they havnt had to pay im not waffling because H onda have always known about it so effectively theyve been lying to us for 11years now and you can ridcule me as much as you want ive got a best mate that lost his leg when his cabs just oh and by the way there is no warning boys take your chances if you feel like it the most laughable thing is Honda dealers have never heard about it !! theyve spent 1.5 gb pounds replacing the stuff under warranty by the way my mates bike was 2020 with 70 miles on the clock Honda tried their level best not to help ive owned 7 blades but Will never buy another
  5. CharlieR85
    Welcome, nobody will ridicule you mate. The ABS issues are well documented on this forum.
    • Agree Agree x 4
