2009 fireblade standard parts list. Most parts will fit at least 08-11. I’m just compiling the list,I’ll add pictures and prices as I go along,but message me if theres anything your interested. Most parts taken off after running in+turning bike into a race bike,so have had very little use. Rear subframe with under tray £125 Front clock bracket £50 Clocks £160 Switch gear-new,think needs plug adding but need to confirm. Front seat. £50 Standard headers+exhaust(excellent condition) £75-delivery would need to be arranged,as heavy lump Standard rear shock £50 Front fork internals-like new £ Standard m/c with pazzo lever (or o/e lever),res+hel brake lines for o/e callipers ,also matching pazzo clutch lever (both in gold) £100 Various screens 1x 08 d/bubble,airblade-new 1x 08-11 tinted-new 1x12-clear,race screen-new Heavy duty s/s seat support unit for race body work £ HRC oil cooler (MGP R-11)+HRC comp rad,both brand new in box,no hoses or fittings. £550 for both Delivery/pick up arranged depending on item,larger/heavier stuff would prefer to be picked up.Any PP fees need to covered your end. Cheers.
Front loom (clocks/indicators/main beam) would you consider selling that part separately? If so are they off a non abs version? Dom
not sure tbh never sold "parts" off a loom,i'll need to look what part of the loom it's off,pm me an offer,and assume postage is uk?
Yeah UK postage. Unless you’re near Leeds or Wakefield? I could collect it. I was thinking £30 including postage?
is it this part you need? https://www.ebay.ie/itm/Speedo-head...32103MFL640-/153913562980?hash=item23d5f69764
Yeah I believe so. It’s where the clocks plug into. And the front indicators and headlights. Oh and tilt sensor. Just not from Australia 32103-MFL-6402 is the part number off the ones I currently have if that helps.
have that,£35 delivered, kind of makes the rest of loom worthless but it's just sitting here. If pp will need to be FF to avoid fees Cheers
It’s a bit risky FF, but I’ll do it. Seen as though your an avid member on here I’ll trust you Send me your details and I’ll send it across now if you’d like? I’m assuming all the connections are all there and ok? None broken...?
Yea all there, there's some tape around part of the outer casing but all plugs etc look good. PayPal is [email protected]
