Custom Dyno mapping PCV
Discussion in 'Mods, Upgrades, Accessories and Products' started by CharlieR85, Nov 29, 2020.
  1. CharlieR85
    CharlieR85 Elite Member
    Think I'm about to reach the point where I'd like to get the bike custom mapped. I've been slowly modifying over the last few years and want to get it done. The stock maps off the dyno website seem excessively thirsty to me. Mods will include, PCV fitted, PAIR delete with block off plates, Akra slip-on with exhaust valve delete, Translogic iS4 quickshifter, intake flapper mod and K&N air filter. (Some of this list are this winters projects)
    Can anyone recommend a decent dyno tuner in the North of England within reasonable reach of Warrington?
    Thanks in advance!
  2. tuktuk
    tuktuk Elite Member
    Dynobike Malton are very highly spoken of. Still a couple hours from you I'd guess.
  3. Trav_1981
    Trav_1981 Member
    I’m contemplating Jordan Bikes in Leeds... they have been mentioned as being good there are plenty of reviews and videos on Youtube.
  4. CharlieR85
  5. CharlieR85
  6. Sam.moz86
    Sam.moz86 Active Member
    Following for the results!
  7. CharlieR85
    April time hopefully.
  8. Sam.moz86
    What are you hoping for? Not bothering with a decat?
  9. CharlieR85
    Just want to make sure its running as well as it can be really. Its pretty good with one of the maps off the dynojet website, it makes it really grunty low down and stops that lurch you can get at 4k. But its made it quite thirsty!
  10. Trav_1981
    Trav_1981 Member
    I’m looking forward to seeing results on mine with a fabricated link pipe and end can (original headers) in comparison to my mates £2k+ Akra system.
  11. CharlieR85
    Undecided, thinking about hacking it out or getting it cut out and link pipe made.
    Got some pics of your link pipe? Where did you get it done? Headers off or done in situ?
  12. Trav_1981
    Trav_1981 Member
    I’ve not had it made yet. Jordan Bikes put me onto a place in Wakefield called STG Performance. I’ve been in touch with them and they want me to take the bike in so they can measure up then make one. I’ll keep you posted and get some pics up when I take it in.
  13. CharlieR85
    Do you think it's going to be worth it? I'm a bit undecided. The cat might even be keeping the noise down to sensible levels which is what I need for trackdays.
  14. Blade runner 1
    Blade runner 1 Elite Member
    I think unless you want to squeeze every ounce of power from your engine to give you a competitive edge on a race track, then it’s probably not worth it. It’ll probably be slightly louder, but not by much.
  15. CharlieR85
    Thats what I was thinking too. Think I'll leave it be.
  16. Trav_1981
    Trav_1981 Member
    I’ll let you know. My mate who just put the Akra system on has kindly donated me his standard system so mine can go back to standard if required. I just de-cat and map anything I have it’s a habit I think.
  17. Sam.moz86
    It's a good habit.
    Are there proven gains for the blade having a decat?
    I cut and knocked out my CAT on a Z1000, it made a considerable difference. I guess that wasn't tuned within an inch of its life from factory though.
    If they could cut it in such a way that if you needed to refit it for track noise purposes that would be good. I can't imagine a decat pushing you over the limit though, unless you're running an SC screamer that is.
  18. andreww
    andreww Active Member
    Took mine to Race HQ Leeds
    It was like riding in on a 600 and riding out on a 1000
    Difference was incredible. So much more low down torque
    He even tweaked my suspension while I was there
    Highly recommend
  19. Sam.moz86
    Did you go on with a complete new header set Andrew, or cut out and sleeve? Guessing you would need to run a power commander after to have it setup?
  20. andreww
    It was a decat system and power commander
    I fitted the system then rode to Race HQ for the power commander and custom map.
    Amazing results
