Ignition problem
Discussion in 'Maintenance' started by 1000rrboyjay, Mar 11, 2021.
  1. 1000rrboyjay
    1000rrboyjay Active Member
    Hi all. I’ve got a problem with my 2008 blade. When opening the throttle, the ignition will stutter badly. I’ve removed the quick shifter, power commander & ignition module. But it still did it. I then replaced the spark plugs (which looked okay) and it still does it. I’ve looked over all connections and they seem fine.
    The bike was involved in a small accident and has been sat for 4 months, however it was only a cracked nose cone and drop on side at about 10mph.
    Does anyone have any ideas..
  2. 1000rrboyjay
    Here’s a quick video
  3. bonjo
    first candidate after 4 months, is fresh fuel
  4. 1000rrboyjay
    I’ve had a fresh tank of fuel. I’ve just taken it out with my Snap-on RTEMP8 gun and checked the temperature of each cylinder at idle and at 5k. #1 was down on the rest by 60,70 or 80 degrees. So I’ll change them over and retest
  5. 1000rrboyjay
    Issue now sorted. Was camshaft position sensor
    • Useful Useful x 2
  6. bonjo
    Well done. Did you use any diagnostic tool?
  7. 1000rrboyjay
    No, next time I went out it came up with a fault code on the dash. Glad to finally have resolved it. Took it out for a good run out for the first time in about 5 months across the Isle of Wight’s new proposed Diamond Course. (Which was my route for the last 13 years haha)
