Intake flap
Discussion in 'General 1000RR Discussion' started by Tony Burrell, Jun 24, 2021.
  1. Tony Burrell
    Tony Burrell Active Member
    Hello,
    I have a 2006 RR6,
    And I had the intake flapper done so it stays open but I have put a power commander 3 on the bike takes about 5 attempts to start from cold, but if I close the flap it starts first time.
    I have been in touch with Dynojet and they haven't been able to find out what the problem is.
    So tonight connected the vacuum pipe back up.
    But now when started and in gear when you put a few revs on the flap closes.
    So for some reason it's the opposite way now.
    I'm sure that prior to removing the pipe and blanking it off you could open the throttle and the flap would open with the engine switched off
    Can anyone help with this.
    Thanks Tony
  2. Selmer50mark
    Screenshot_2021-06-24-20-16-22.png I removed the whole lot off mine ,,,,, never had an issue with starting
  3. Tony Burrell
    If I remove the pc3 it starts first time every time
  4. Selmer50mark
    Strange :confused:
    Can't help with this one , never had anything to do with pc's
  5. Jez
    it looks like a map issue to me
  6. NS400R
    NS400R Elite Member
    I did the flapper mod to mine and had the pc3. Never any starting issues. TBH, I don't think the PC3 did anything. I'd junk it. The flapper mod smooths the bike out.
  7. Slick
    have you plugged in a laptop whilst the bike is running, ie TPS and injector readings are Ok
  8. Tony Burrell
    Ok I'll have a look.
    Do you know what the readings should be?
  9. Slick
    with the ignition on but engine off the TPS should read 0 to 100%.
    if all over the place you have a connection problem, if not reaching 100 you need to calibrate
