anything complicated ? or is it just bleed the two cylinders ? local guy suggested its got to go to a dealer.but im guessing he was confused with the previous multi point bleed fiasco ? any pointers ? tia
I did my 2017 blade, and its straight forward. Put rags everywhere to catch any stray drops of brake fluid. I got a good tip: use a tie wrap to hold the brake lever closed overnight. It allows any trapped bubbles to come up with teh system under pressure. Makes no sense.. but it worked on mine!! I found the rear brake fluid was much worse that the front!
