Picked up a written off 06 blade for free. Looking for donor parts if anyone has spares or am willing to pay!! Crankcase bottom end Sump case Swing arm Rear wheel Full exhaust system RH peg/rear set Subframe probably loads more any help would be massively appreciated
I have a rear wheel and the rear part of the exhaust. Also front wheel, forks abd rear shock if that helps? Where are you?
Surprisingly the forks n monoshock are still good!! 100% need that rear wheel/exhaust... the front has a slightly warped lip but still holds the tyre bead so hoping it can just be repaired. Im in Hampshire
At this time of night, alas no! But it is about time I do something, so will see if I can break the ice tomorrow and get some taken.
