CBR1000rr 08-19 List parts I have for sale
Discussion in 'Parts, Accessories & Clothing' started by vic_ster51, Feb 14, 2023.
  1. vic_ster51
    vic_ster51 Active Member
    CBR1000rr 08-19 List parts I have for sale please feel free to ask about fitment and more info, price etc
    Have more parts aswell
    Brand new spark plugs ngk
    new titanium disc bolts
    puig double bubble clear screen 12-16
    sp swingarm silver
    track frame no v5
    Clipons oem pair with oem weights
    Servo eliminator
    oem clock bracket
    Rear subframe x 2
    battery tray
    black multi spoke wheels 08-16
    As new oem front brake discs in gold 08-16
    rear wavy disc
    front forks with full ktech cartridge kit 08-16
    sp ohlins rear shock revalved 08-19
    ebc front brake discs 08-16
    Galfer wave front brake discs 17-19
    airbox
    bmc air filter
    radiator
    oem downpipes headers 08-13
    fuel tank x 2
    fuel pump x 3
    Complete yokes x 2 in silver
    oem front brake master cylinder complete
    rear brake master cylinder
    Gilles x factor rearsets in black
    OEM matt black fairings 12-16 (bought new from usa) complete kit with matching sp solo seat hump
    Evo tech tail tidy
    Repsol fairings 12-16 (sp 2015 repsol) No belly pan or front mudguard
    Sp Yokes ohlins forks bottom and top
    Black oem front mudguard
    08-11 side fairing trims
    08-11 air duct inner trim panels
    throttle cables and tube and housing x 2
    lhs light switch x2
    oem rear indictators
    Rad cap and housing
    clutch perch x 3
    sidestand x 2
    rear caliper
    braided brake lines front and rear
    Rear clear led oem tail light
    Engine mounting bolt set
    Loads titanim bolts some new or basically new - fork pinch bolts, yokes, caliper bolts, spindle etc etc
    08-11 oem headlight
    As new sprocket carrier
    UK spec lockset
    leo vince end can (not best shape but useable)
    08-11 clock wiring loom front
    12-16 full main wiring loom
    Quick release fuel cap
    Axles, spindles etc
    Loads new sealed in bag honda engine seals and o rings, washers etc ideal overhaul
  2. rocket
    rocket Active Member
    How much for the forks. Black or gold outer tubes?
  3. vic_ster51
    Black forks - full ktech cartridge kit fitted, top notch
    £675 posted
  4. vic_ster51
    Also have a standard set big piston forks in black from 2015 bike non abs fits all years 08-16 for £425 posted
  5. Coda
    Coda Active Member
    Do you have a dash for a 12-16? Even a broken one is fine. I just need part of the housing, mine got melted in the summer because of a double bubble screen :oops:
  6. Broadie
    Broadie Active Member
    I'm still looking for a fan relay if you have one?
  7. kloun5000
    kloun5000 Member
    How much for those if you are willing to send them to me
    Evo tech tail tidy
    08-11 oem headlight
  8. vic_ster51
    Hi, sorry i dont. You can buy the cases separate, lots 08-11 on ebay for example £30 they do the job. Not sure if any for 12+ have a look. Its a simple job to change
  9. vic_ster51
    Hi, as in the 4 prong relay in the fuse box?
  10. vic_ster51
    PM sent
  11. Broadie
    That's the one. There's 2 of them identical side by side. I only need 1.
  12. AbuJane
    AbuJane New Member
    Hey Vicster, you may not have seen my post in "Wanted" forum: Hey everyone,
    I am trying to get my 2009 track bike road legal again, for daytime use so no lights. It doesn't have the bit that the number plate is attached to (hence stand/thing ). Anybody got one that has come off their bike when they have prepped it for the track?
    If you have any other reasonable suggestions i would be grateful for those too.
    TIA
    Mike
  13. Coda
    Coda Active Member
    I replied in your other thread.
    https://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/99562
  14. AbuJane
    AbuJane New Member
    Thanks Coda, really helpful, can't believe they want £100 for that!!! Hoping someone has one going cheap as this new bike is killing me and i haven't even ridden it yet
    Thanks again bud
  15. Lockers5693
    Lockers5693 New Member
    Is the bmc air filter still available?
  16. vic_ster51
    Sorry sold
  17. Lockers5693
    No worries, thanks for the reply
  18. shahwales
    shahwales Active Member
    Hi mate. Price for servo eliminator and sparks please
  19. vic_ster51
    Both sold im afraid
  20. NickEastCoast
    NickEastCoast New Member
