Replacement Key
Discussion in 'Lounge' started by bradt, Feb 21, 2023.
  1. bradt
    bradt Elite Member
    Somehow I've misplaced my ignition key (2009 bike) luckily I have an original spare how and where do I get a replacement and how much are they ?
  2. Boothman
    Hopefully a dealer can help @bradt - good luck
  3. bladey
    bladey Senior Member
  4. Jez
    I bought a key and a micro chip off Ebay, I had the key cut local then programmed the key chip using instructions off Youtube. all worked fine
    dealer wanted about £150 for the key, I paid about £20
    • Useful Useful x 2
  5. B626
    B626 New Member
    Just had the same problem with my 2007. Ended up getting 2x extra keys cut from an ebay seller (https://www.ebay.co.uk/itm/125446745496) which were perfect ,even look identical to my existing OEM honda keys.
    To program you can put together your own harness but for the sake of £20 I just bought one also off ebay (https://www.ebay.co.uk/itm/223986882999)
    I just followed the procedure in this video
    Very straightforward procedure honestly once you've got fairings off...
    #5 B626, Feb 22, 2023
    • Thanks Thanks x 3
  6. Jez
    The pain in the arse is taking the fairings off, why do most jobs require this, The R1 fairings came off easy, the CBR is a pain for this, Why should you have to remove a fairing to program a key
  7. bradt
    bradt Elite Member
    UPDATE.....key found, thanks for the advice given in response to my post.
  8. Boothman
    Result :cool:
  9. Jez
    Any chance of you looking for mine:D
    • Funny Funny x 6
  10. bladey
    Now try and find the bike to stick it into. :D:D
    • Funny Funny x 4
  11. bazzashadow
    bazzashadow Elite Member
    I would wonder about eBay key cutters
    They have you key and know where you live :eek:
    Or is it just me
    • Agree Agree x 3
  12. Coda
    Coda Active Member
    Agree but there are some with good reputation and that would be extremely low risk. Could always get them sent to another address like you do with your naughty toys :D
    • Funny Funny x 3
  13. Jez
    mine came as a blank from Ebay, got the local key cutter to duplicate then programmed the chip.
    security is not an issue in my case
  14. B626
    B626 New Member
    They are not able to duplicate the HISS coding without an existing key nearby. The only risk is they can disable steering lock on the bike - but if that's your only security measure then....
  15. Jez
    I am not sure but now I think they can duplicate keys and chips, but they would need the original key to do this,
  16. AbuJane
    AbuJane New Member
    Following this post so i can find it later
  17. AbuJane
    AbuJane New Member
    Guys, thanks so much (again) for your help and guidance. I sent the eBay guy a photo and he will cut and post the key to me in the morning! How fantastic is that!
    Will order one of those reprogramme sets too - thanks again.
    mike
  18. Jez
    From memory, the red plug that was supposed to be behind the fairing was actually more under the tank, they must change positions on different bikes
  19. AbuJane
    AbuJane New Member
    @B626 - i don't suppose i could rent your harness please? Followed the link and they are out of stock, contacted seller and they said they are not sure when they will have them in again.
    Mike
  20. B626
    B626 New Member
    Sent you a PM mate
