How many sets of brake pads for 5 days on track - newbie
Discussion in 'Trackdays' started by AbuJane, Mar 25, 2023.
  1. AbuJane
    AbuJane New Member
    Hi guys i wanted to check how many sets of brake pads you think i might need for 5 days in Spain. I know its not a straight forward question but as a newbie - so hopefully won't be pushing too hard but being a bit sensible for once in my life - will i get away with a new set on and a spare set or will i need more?
    #1 AbuJane, Mar 25, 2023
  2. Muffking
    2 sets including the ones on the bike will be fine.
  3. AbuJane
    AbuJane New Member
    Thanks mate thats really helpful.
    Any recommendations on which pads and/or where to buy them.
    So just to be clear:
    • The set that is on the bike
    • an additional 2 x sets of front pads
    • an additional 2 x sets of rear pads
  4. Muffking
  5. Coda
    Coda Active Member
    Not sure you’re gonna need 2 spare sets of rears. Unless you really really use the rear all time.
    If you get SBS sintered make sure they are the RST not the RS. The RST are the slightly better version.
    Or just get GPFAX but I think you’ll need to switch em back if you take the bike back on the road?
    Also make sure you take some good brake fluid (Motul 660) and a way to bleed the brakes.
  6. AbuJane
    AbuJane New Member
    As ever mate, thanks so much for the advice - will do!
  7. Neils400
    Neils400 New Member
    For a noob - I doubt you'll go through 1 set but take another set just in case.
    Depends on the track as well to be honest.
  8. Cookster
    Cookster Active Member
    ive just done 3 hard days a cartagena and only wore though half a set
  9. Jay Floyd
    Jay Floyd Active Member
    Yep same here after 3 days at Portimao, Started off with a new set.
  10. AbuJane
    AbuJane New Member
    Yeah as a complete noob i doubt i will be too harsh so will change current pads to track pads and take a spare set.
  11. AbuJane
    AbuJane New Member
    Thanks mate, appreciate the response
  12. AbuJane
    AbuJane New Member
    Thanks Jay info from you and @Cookster helps
