Advice
Discussion in 'General 1000RR Discussion' started by Itsafix, Apr 7, 2023.
  1. Itsafix
    Itsafix New Member
    Cleaned the bike a few weeks ago with muck off bike wash and a snow foam and put it away went out today and noticed staining on the gearbox and engine covers any advice on how to remove staines tried the same cleaning products and a few others but nothings worked?0
  2. PauloHRC
    PauloHRC God Like
    Did you rinse it off properly, sounds a daft question but it looks like you've sprayed it on and left ito_O
  3. Broadie
    Broadie Active Member
    Muckoff is pretty much tfr based so will just keep going on ally if not fully removed. Possibly GT85 might lift it or cutting compound ( t cut , autosol ect ) but could be looking at a repaint.
    Good luck with it.
  4. Itsafix
    Itsafix New Member
    It never dryed on and
    Never left to dry on,washed of then towel dry.
  5. Itsafix
    Itsafix New Member
    Gt85 done nothing need get some cutting compound and try that
  6. Dave dunlop
    Dave dunlop Elite Member
    Snow foam and TFR is unfortunate way to corrosive for motorcycles Unless used correctly.You only need a small amount of residue thats not properly rinsed off and it will stain anything it comes into contact with. Seen this all to often and very difficult to rectify especially on bare metals… not sure what the best solution is in your case, looks permanently damaged
  7. Manofsteel
    Manofsteel Well-Known Member
    I had a similar problem with my old blade so what I did was re wash it with Motul bike wash then rinsed well and while it was still wet I sprayed all the casings liberally with Autoglym vinyl and rubber care and left them to dry naturally overnight no toweling off and the next morning they were like new with a lovely shine
    • Useful Useful x 3
  8. Itsafix
    Itsafix New Member
    sorted t cut metal polish
  9. bradt
    bradt Elite Member
    You can relax now and get out for a ride knowing you haven't got to buy new casings
  10. bonjo
    I use bilt hambert snow foam with a pump sprayer on wheels and lower parts of the bike including the engine. No such staining issues
  11. Slick
    Muck off is a bit too strong IMO and needs to be used with caution especially around bare metals. Muck off is more of a degreaser for general TFR use Bilt Hamber Snow Foam at 4%PIR
  12. bazzashadow
    bazzashadow Elite Member
    I had the same happen with muck off on my painted rear pegs
    Will never use it again
    Had to polish it out :mad:
  13. bonjo
    Must sya I used the original muc off pink for many years without any issue. I was very mild. I since switched to bilt hambert snow foam
