2004 cranks but wont start. HELP Please
Discussion in 'Maintenance' started by Jason3108, Feb 10, 2023.
  1. B626
    B626 New Member
    If no error codes stored on ECM this would indicate either fuel pressure supplied is incorrect and so injectors do not function or an ECM failure as it is unable to self diagnose a fault.
    First step would still be to confirm fuel pressure and fuel flow rate.
    Side stand up would only be a problem if the bike was in gear, double check it's in neutral to eliminate a faulty side stand switch too I suppose?
    #21 B626, Mar 16, 2023
  2. Jason3108
    Jason3108 New Member
    Sorry, I meant the MIL won't blink if stand isn't down according to that document. I have confirmed side stand, neutral and TIP switches/sensors are all ok.
    As far as fuel pressure, bike doesn't start so I can't measure fuel rate at idle but I can definitely measure volume and time and hopefully that wil be enough to work out if there is enough pressure. I am thinking more and more that I am looking at fuel pressure problem now.. I changed fuel pump a month ago and the pressure regulator sits right next to it in the same bracket. I may have knocked it or bumped it just enough to create an issue that didn't start straight away. The pump was quite difficult to get out of the bracket. Maybe the pressure reg shit itself. I will try measure fuel pressure/flow and also try forcing some fuel into rails by sealing fuel hose in a bottle with fuel in it and squeezing. If I get a cough or splatter then there is the problem.If not I will put an air gun into bottle and send it with some pressure. I will pull it out on the weekend and have a go. I am a little excited that I have something to try that could be the answer after all the testing I have done. Thank you guys for advice. I am actually excited to try because I have just about given up. I will let you know soon.
  3. Mamado
    Mamado New Member
    A bit of a daft answer but I assume plenty of fuel in the tank
    شركة تنظيف كنب في دبي
    تعد شركة تنظيف كنب في دبي الخيار الأمثل للحصول على خدمات تنظيف الكنب المتخصصة والفعالة. توفر الشركة خدمات تنظيف الكنب للمنازل والمكاتب والمحلات التجارية في جميع مناطق دبي
    شركة تنظيف كنب في الشارقة
    تتوفر خدمات تنظيف كنب الشارقة بأسعار مناسبة وبأشكال مختلفة لتناسب احتياجات العملاء المختلفة.
    شركة تنظيف كنب في عجمان
    تتوفر خدمات تنظيف كنب فى عجمان بأسعار مناسبة وبأشكال مختلفة لتناسب احتياجات العملاء المختلفة
    Mamado
    This message by Mamado has been hidden due to negative ratings. (Show message)
    • Downvote Downvote x 4
  4. Broadie
    Broadie Active Member
    When you switch the bike on. How long does your fuel pump prime for?
    Sounds like you have a leak between the pump and the tank outlet. Internal tank hose should be R10 grade, I think.
    #24 Broadie, May 24, 2023
