Cam chain
Discussion in 'Maintenance' started by Andy62, Jun 30, 2023.
Tags:
  1. Andy62
    Andy62 New Member
    Cam chain needs replacing at 19,000??
    2016 bike
  2. Iain
    Iain Active Member
    Does it? Or is it just the cam chain tensioner?
  3. Andy62
    Andy62 New Member
    No it's the chain,took it two mechanics
  4. Iain
    Iain Active Member
    How did they come to that diagnosis?
    How much did they charge to tell you that?
  5. Andy62
    Andy62 New Member
    £0
  6. Broadie
    Broadie Active Member
    Technicaly the chain makes the noise but it's down to the tensioner not working correctly.
    Where you quoted a price and what would be done?
    • Agree Agree x 3
  7. Andy62
    Andy62 New Member
    Yes new camchain and tensioner and guide channel.
  8. Broadie
    How much?
  9. Andy62
    Andy62 New Member
    Alot
  10. Broadie
    People are actually trying to help you.
    This could probably take you 2 hours and cost between 40 and 80 pounds. You'd spend more time dropping it off and picking it up.
  11. Andy62
    Andy62 New Member
    Yes I know cheers
    I'm just worried it could be something else wrong,it doesn't do it when it's cold,then rattles like a bitch when it's warm.
  12. Iain
    Iain Active Member
    Sounds like a typical CBR cam chain tensioner issue - easily diagnosed to those that have suffered it, or a decent mechanic.
    Equally easy to scare unsuspecting punters into replacing more than needed, ie the chain.
    The only way to tell if the chain and guide plate need replacing is when the engine is in bits - not just by listening to it.
    The idea of coming to a forum is to ask for opinions and share knowledge - open up a bit and we might save you a dew hundred quid.
    • Agree Agree x 5
  13. Andy62
    Andy62 New Member
    Cheers for that,I'm going speak to the mechanic Monday.
  14. raphael
    I’d be gutted spending all that on labour when it’s just a 30 or so quid part you can do yourself in an hour.each to there own though, hope he don’t bend you over to far
  15. Andy62
    Andy62 New Member
    OK
  16. Ian E
    Ian E Active Member
    As above, more likely to be the Camchain Tensioner than the actual Camchain. Blades are well known for it.
    CCT expensive new from Honda, but you can save a few quid if you are not in a rush for delivery (e.g. https://www.ebay.co.uk/itm/155042038256 ).
  17. Jay Floyd
    Jay Floyd Active Member
    A common weak area with Honda....... I fitted a Manual CCT on my old 2011 blade, no issues :)
  18. SimonRR
    SimonRR God Like
    I fitted a manual CCT on my 05 blade, worked a treat, cam chains should last more than 19k I would have thought?
  19. Andy62
    Andy62 New Member
    Cheers yes been looking at those.
  20. Broadie
