New chain
Discussion in 'Maintenance' started by drewl999, Apr 17, 2012.
  1. drewl999
    drewl999 Active Member
    Im after getting a new chain and was wondering if you need to get new sprocket too? My bikes only a year old and done 3200 miles so not worn out, just fancy a nice gold shiny chain :D
  2. Garyb
    Garyb Moderator.
    I replace sprockets with chain. So yours have already covered 3200 miles. IMO it won't be long before one starts working against the other? Knackering the chain?
  3. Andrew
    Andrew Active Member
    If your happy that both sprockets are as new with no wear, then I don't see why you couldn't fit just a shiney new gold DID chain.
    But if there's wear in them for what you can get the kit for over the price of just the chain you'd be a bit mad to not buy a full kit.
  4. fez.57
    fez.57 Well-Known Member
    I bought a gold D.I.D kit 2 months back and it was only an extra £20 for front and rear sprockets so i thought why the hell not
  5. Andrew
    Saying that if I was going to the trouble of fitting a new chain just for bling factor i'd deffinetly be fitting a new rear supersprox rear sprocket!
  6. BLAGGERS
    BLAGGERS Well-Known Member
    C+S as a kit. As said, its a no brainer mate.
  7. megawatt
    megawatt Well-Known Member
    Yeah, buy a kit, but order 1 tooth smaller front and/or 2 teeth more on the back !!!:D
  8. Bobmg
    Bobmg Active Member
  9. MrB
    MrB God Like
    +1
  10. Bats
    Bats Active Member
    The full set all the time!!
  11. gRRandeelion
    gRRandeelion Active Member
    Main dealer replaced the chain on my RRN at 16000 miles said both sprockets still in very good condition and didn't need replacing, sold it with 32000 miles showing still with original sprockets and second chain. Was also still using original discs and pads front and rear, used in most weather conditions. They knew how to make FireBlades in the old days.
  12. JM1
    JM1 Active Member
    32k on the original pads? You have got to be kidding me.
  13. daveyboy
    daveyboy Active Member
    Must have rode like a right fanny! :D;):confused:
    #13 daveyboy, Apr 19, 2012
  14. drewl999
    is changing the sprockets and chain something i can do or am i going to have to get it done professionally?
  15. megawatt
    Piss easy job mate, if you have a 50 quid chain splitter/rivetter.
