04 steering damper
Discussion in 'General 1000RR Discussion' started by And7rp2, Nov 10, 2015.
  1. And7rp2
    And7rp2 Elite Member
    Got a problem with the track bike, hope someone can help ?
    Not sure if its speed related or time related but after about half a lap of oulton the HESD comes up on the dash and it feels like the resistance has gone, any ideas ?
    Is it electrics or the actual damper ?
    Cheers
  2. Muffking
    If you don't get it sorted before we're at the same track next time then let me know as we can swap them over, plus I could take the one off the road bike too.
  3. And7rp2
    Cheers Gary nice one
  4. Chris.93
    Chris.93 Member
    There is a way to test them .
    Will need to get front wheel in the air, with abba stand or a mate holding bike over on side stand .
    Put bike in 1st, hold throttle fully open, and turn ignition on. Hold throttle for 5 seconds .Now hold bike over so front wheel is in air .Turn bars lock to lock continuously .The damper will be loose then it will stiffen itself up.
  5. And7rp2
    There lies my problem !! And one of the reasons I've put a wanted ad for a side stand !!
    Thanks for the info if I get front end up I will have a go
    Cheers
  6. Chris.93
    Chris.93 Member
    Would only need the side stand switch to be connected or shorted togther to test the damper, I don't think it has any effect on it working when riding .
    But I'll double check at work tomorrow for you .What year is your bike?
  7. And7rp2
    It's an 04 , but I need the side stand to get the front wheel in the air, coz I've only got a head stock or bottom of fork stands
  8. Chris.93
    Chris.93 Member
    Ahh I Gotya .
    Could try a rear paddock stand and a Jack on down pipes
