05 blade not starting
Discussion in 'Maintenance' started by garethS, Aug 5, 2014.
  1. garethS
    garethS New Member
    hey,im new to this and my spelling is shitty sorry. my blade is not a baby its her 10th birthday next year and i dont have the money for a upgrade,she was running fine til my brother puled her out and and started her, he then staled the motor on a cold start and it doesnt start up now,maby the motor is fluded but its been 2 days now,it turns over fine all the lights on the clocks are working and the fuel pump is priming please can someone help i read other threads but nothing with my problem on them :mad:
  2. garethS
    garethS New Member
    all the switches are working fine pulled the pump relay and all the common stuff, battery is getting flat,is it ok jump start from a car battery?
  3. ColinBR
    Is it possibly the kill switch playing up mate?
  4. martinowen
    Has it been sat a while? May have dragged some shite through and blocked the injectors etc
    Or may just need plugs
  5. Muffking
    Is it turning over?
    Has the tank been up i.e. is the fuel line been trapped?
    Has the tilt sensor been moved off position i.e. for a fairing swap?
  6. garethS
    garethS New Member
    turns over fine tested the kill switch if i turn it on the pump starts priming, plugs and filters newish done about 1000 km on them,the bike is a every day driver and i tested the tip sensor the motor doent turn over if i put the sensor upside down tested spark the best way ever by holding the plug and cranking it they all work fine, the bike wants to start now and then but only gives a fart and keeps cranking
  7. martinowen
    Was the fuel low at the time it stalled
  8. masterblader
    masterblader Active Member
    Check the side stand, handlebar kill, and cock pit tilt switch. These kill the sparks a tester and WD40 may give you a result for starters.
  9. racman
    racman Active Member
    Flooded. Crank withthrottle open and should fire after a few secs
  10. garethS
    garethS New Member
    thanks for the help turned out to be a bad batch of fuel,i removed the plugs and cranked her over for 30 sec new plugs and new fuel and she is going fine
  11. garethS
    garethS New Member
    didnt start with throttle open,airflow sensor was dirty thanx to honda not cleaning it when the bike went for the last serves,bike flooded again after starting with new plugs and new feul and holding the throttle open flooded it even more but she is running good now,had her on the open road for about 170km at about 240km/h that is about 105 miles at 150 miles/h:D and after that the black petrol smoke also stopped,motor is stil fine with only 14324 miles on (23053km),thanx for all the help
