'06 fireblade for oil grade?
Discussion in 'Mods, Upgrades, Accessories and Products' started by bambo838, Mar 9, 2013.
  1. bambo838
    bambo838 Active Member
    Hi. Im about to change fork oil on my 06 blade. The manual advises to use 10w but i was thinking of using 15w to make the standard forks a bit stiffer. What do you thing about my idea? Has anybody else done it.
    I should ad that I mostly use my bike for trackday and Im going to almeria with fe over easter.
    Thanks in advance for any advice.
  2. wedgiewolves#223
    wedgiewolves#223 God Like
    I always keep oil all the same so did brooks suspension when they fitted my internals just used a better oil . There is enough adjustability in the forks to counter the weight of oils
  3. bambo838
    So Lee what oil would you recommend. I normaly use motul.
  4. wedgiewolves#223
    I used motul same weight as normal brooks used k-tech oil bud
