08-12 Race fairing fitting tips
Discussion in 'General 1000RR Discussion' started by wedgiewolves#223, Nov 29, 2012.
  1. wedgiewolves#223
    wedgiewolves#223 God Like
    I dont know whether to dry fit my CRC fairings, or just get them painted and sort out when a bit warmer.
    Only 2 parts im concerned with Should be same (08-12) .
    Rear fairing please see picture seems to have only 2 mounting points at the front on the bottom is this nice and secure with just these.
    Also do you have to remove the original rear undertray holds rear light (not the white one with HRC) with the 3 mounting bolts for the number plate to get the race undertray to fit. Was thinking about a odd blast with the race fairings on so would like this to stay.
    Bottom belly fairing will it have to be chopped to allow use of stand.
    I know all race fairings gonna fit differently but worth asking.
    Any help appreciated
    Wedgiewolves.
  2. Dano28
    Dano28 Active Member
    Hi mate, looking at that I would guess that they fix into the holes that hold the stock undertray on...I have race fairing but didn't use the undertray in the kit so I could keep my stock tray on as it was going to be a road/track bike. that was only held on by 2 bolts, fitted into where the pillion seat strap secured to on the subframe, was a tight fit to the frame too so nice and secure. I had to cut a slot out to fit around the brake light too, so in short I would guess that you would need to remove the undertray as well as the brake light if you want to keep them whole. Hope that makes sense...
  3. wedgiewolves#223
    Yeah I looked and most fit as yours into the seat strap but this does not so ill secure from underneath if I go for a blast on the road ill blu tac my number plate on my helmet ha ha cheers for answering
