08 onwards repsol screen decal
Discussion in 'General 1000RR Discussion' started by RRpaul, Oct 30, 2016.
  1. RRpaul
    RRpaul New Member
    I fancy fitting a db screen to my 2010 repsol blade .
    Anyone know if the OEM decal will fit ok on the different contour on a double bubble?
  2. Dave The Blade
    Dave The Blade Active Member
    If you mean replacing your screen with the Honda High Screen then I don't think the standard decal fits because the screen isn't a traditional db it's just, well higher all over. If you're thinking of an aftermarkert db maybe it will depending where the bubble starts. I thought there were different part numbers for the decal depending on which screen but not 100%.
  3. stupot
    stupot Active Member
    I have just done the exact same thing and I had some stickers made up. Separate ones.
    PM me your email and I can send you some pics. I may have a set left.
