08 Starting Issue
Discussion in 'Maintenance' started by JM1, Dec 25, 2011.
  1. JM1
    JM1 Active Member
    08 won't start. Was fine a few weeks ago, sitting in garage on charger, now won't start. Turns over fine until the battery runs out, but don't think it's getting any fuel. Pump doesn't prime every time ignition is switched on. Do you think it's a fuel pump issue? Could a dodge battery cause these symptoms?
    P.S. Also have PCV fitted but never had any issues related to it.
  2. Si.
    Kill switch? I know it sounds daft....but I did the same last week...turns over but doesn't fire?
    I was scratching my head, took off the seat and messed with the wiring and fuse box.
    It was the kill switch :eek:
  3. JM1
    JM1 Active Member
    Hehe, that was the second thing I checked mate. After fuel!
  4. Si.
    Checked your fuse?
  5. Benn The Pig
    I'd check the switch on the clutch lever when u pull it in to start the bike????
  6. masterblader
    masterblader Active Member
    Has the tank been removed? If so the possibilty could be the snap connector for the pump has come adrift hence no whirring from the pump to prime the injectors. The battery seems to be OK as its turning the motor over so after 5-6 stabs to start up the battery will die its only a 7amp/hr.
  7. Nutty Tart
    Nutty Tart Well-Known Member
    I would check the side stand switch now . If you can spray it in degreaser then contact cleaner or just plain old WD40
  8. Benn The Pig
    NT that would only be an issue if the bike was in gear I think
  9. Nutty Tart
    Good point Benn .... scratch that then ;)
  10. ColinBR
    Is it an optimate charger mate?
    Reason I ask is that. Kind of silly really. I've stuck mine on before and the light goes on the charger, so I think it's charging. Then a week or so later it doesn't start.
    Only for me to realise I haven't switched it in at the wall ??? Hopefully it's just that mate but to be honest I wouldn't admit it on this forum. It might make u look daft like me :)
  11. JM1
    JM1 Active Member
    I'd prefer if you didn't post in my threads. It's hypocritical.
  12. JM1
    JM1 Active Member
    No, tank hasn't been off for ages.
  13. JM1
    JM1 Active Member
    Charger is definitely working and the starter cranks. I think masterblader was on the right lines - seems to be fuel pump related.
  14. JM1
    JM1 Active Member
    The fuel pump sometimes primes, but I think the final whirring sound is missing. Sounds daft I know! Could a knackered battery cause the pump not to prime properly? The bike has stood in my garage since last use. N.B. It has been washed but I don't think this is a water issue.
  15. Benn The Pig
    No I was genuinely trying to help I have no hidden agenda unlike some, as said before!
  16. dan.1moore1
    Don't have to do that on a Honda mate
  17. Benn The Pig
    I always just do it I never actually tried it without pulling it in lol
  18. dan.1moore1
    I reckon its a weak battery not giving enough juice to fully power the pump
  19. slowr1der
    slowr1der Active Member
    i would go down the battery route mate, although on a different bike i had the same kind of problem on my 08 R1. It was under warranty and took it back to the dealer, battery replaced and problem sorted.
    Ben thats a GSXR thing lol
  20. JM1
    JM1 Active Member
    So do I, will try a new battery soon
