looking for a 08+ trackbike..... if possible with WoW's.... the bigger the spec the better, but would consider a stock bike for the right price.... Cat B,C or D considered as don't need a V5, even a still damaged bike ( no damage to frame ), needs to be running! you can either send me a mail [email protected] or a pm here anywhere south of Leeds would be fine for pick up! looking for something from end oct/ begin nov Title says 08+, but it should be 09+ ;-) don't want an 08 bike, don't want the risk that it's an oil drinker thanks
got an 09 thats going up for sale. spec is WOW's with discs+dunlop wets,captive spacers on both sets of wheels Ohlins TTX rear shock K-tec 20mm valve kit full akky system with baffle 100db with baffle in Bazzaz with TC, quickshifter and the handle bar map switch,wet+dry map,plus TC light so you know when it's working. SES race clip ons GPR steering damper 19/20 Brembo master cylinder Alloy front subframe with catch bottle Captive spacers in both sets of wheels Captive rear brake caliper Promac rearsets Frame and engine crash protection,carbon frame+gb engine cases bendix mcr pads Q/R fuel cap 4 month old 520 chain-pro link-£160,new this yr. engine has had a little work done,just a skim off the block to give more compression,but still able to use standard gaskets,full strip+refresh at start of this yr(march/april) inc.shells,rings,gaskets,brand new gearbox ,slotted cam wheels so we could advance the timing (these are 320 quid from padgets!!!),balanced rods.dyno'd at start of yr showing 182.45 bhp,very very healthy,got the sheets. all numbers present,and matchg upto the original registration document. £6450 little bit of damage to end cap on can but only cosmetic,and fairings have been repaired,again work fine just cosmetic. pm me if you want any more detals,pics etc.
I'd be VERY interested in this buddy. Any pics to [email protected] would be good when you have chance
there loads,check motoforum or Trackdayriders. lot more track/race bikes come up for sale on those forums.
should be sorted soon, so thanks for help and interest guys...... I'll hopefully have a nice 2013 in the garage soon
My 12's sweet only 1200 miles but its first track day in Fast group was 11 miles on clocks and has been since
