1000RAE, Indicator Broken
Discussion in 'Maintenance' started by Stuart Coutts, May 20, 2018.
  1. Stuart Coutts
    Stuart Coutts New Member
    Front right indicator stopped working.
    Indicator bulb is fine, Power to the indicator is fine (positive shows 12V-ish, negative switches between 12V-ish and 0V-ish, Rear right indicator flashes quickly, Front and Rear left indicators are fine. Right indicator light on dials does not work unless the front right indicator bulb is removed; when removed the dial light flashes quickly.
    I am at a loss. Any suggestions would be really helpful! Thanks in advance!
  2. Muffking
    I can see your confusion, although the first thing that stands out to me is that you say the positive lead reads 12v, but the negative lead switches between 0-12v. Shouldn't is be the positive lead that does the switching so it's not live all the time?
  3. nigelrb
    I am wondering if there might be a pinched wire somewhere around the head stem. Generally, when one bulb flashes quicker than the other, it signifies a blown bulb (which you've discounted) or a short in the wiring.
  4. Lozzy
    I'm more interested in if your avatar is to scale Stuart :D
    • Funny Funny x 2
  5. nigelrb
    I think Stuart's computer might be 'on the blink' too!
