Hello, I know this has been covered over and over but i'm struggling to find a model number for replacement downpipes with no cat. I understand the best thing to do is buy a set of headers from the US? But what model number would i need to fit my bike? Took 18150-MGP-D60 off my bike. Ive found 2 sets in the US.. 18150-MGP-A90 Or 18150-MGP-A00 I dont see a difference between the two did they revise it to A90 on the 14> bikes? So which set would you guys say get or would them i picked out even fit!? dont want to order a set from the US to find they're wrong. Thanks for any help.
Pre 14 headers have a different diameter to connect to the silencer, so no they will not be suitable.
True. Depends if your also going with an aftermarket end can unless you already have one to suit the 60mm.
To be honest im not too worried about the 50mm or 60mm outlet just want it to fit the ports and miss the sump under the bike. But if any pre 14 headers will fit thats good. thanks for your help!
Pre 14 headers will fit with no issues! But 2014 model had lots of changes including smaller bore headers for increased midrange and obviously fuelling to suit. Did a lot of research on mine and if I’m honest it’s not worth the hassle. The cat on the later models is really free flowing and not massively restricting.
