1000RR Fireblade Galespeed wheels
Discussion in 'Parts, Accessories & Clothing' started by megawatt, Mar 16, 2013.
  1. megawatt
    megawatt Well-Known Member
  2. IcarusGreen
    IcarusGreen Elite Member
    I'm watching, I like the comment at the bottom.
  3. martinowen
    He offered these to me at 800 delivered, if I had the cash I would of snapped them up
  4. fez.57
    fez.57 Well-Known Member
    Can they be fitted to an rr-8 if you get the correct spacers ?
  5. megawatt
    If that is all you need , easy to get spacers made. Are the spindles the same size and length?
  6. fez.57
    I have no idea tbh, i know nearly all dymag wheels can be transferred to any other bike with only spacers required but not sure if galespeed are tge same
  7. megawatt
    Ask the seller if you want em?
  8. IcarusGreen
    Fez - you do know they're not white ;)
  9. Stefanos
    Stefanos New Member
    i think i heard that the rear wheel is not fiting to a 08 but a question to gallespeed directly must solve the enquire ;)
  10. fez.57
    Yeh i was thinking i could get them powder coated but its probably not worth the extra expense. i will just have to wait untill a nice white pair appear
  11. martinowen
    Powdercoat only gonna cost you 50quid a wheel fez
  12. fez.57
    Yeh and spacers and what ever else is required and tbh im not really in love with them. if they were dymag, marchesini or pvm i would have been much more interested
  13. martinowen
  14. Dela
    Dela New Member
    Rear wheel fit, front doesn't.
    Galespeed will not sell spare parts required to make the wheel fit due to the torqued down spacer on the front wheel. I was told to ship my front wheel to Japan to get it re-fitted with the spacer required for the discs of the 08.
    Notice that the front hub says 'do not dis-assemble'. Their mails show they take it seriously. That's my experience at least when I went from '06 to '08.
  15. megawatt
    What do you mean it doesn't fit. Most things can easily be modified so that they do fit. Take some pix and measurements and explain what you mean???
  16. Dela
    Dela New Member
    Front wheel is not the same size on SC57 compared to SC59.
    The same reason you cannot use original wheels from SC57 to SC59. I just relayed the information I got from Galespeed, since I wanted to take my wheels over to my SC59. Their direct message said 'we can modify the wheel, we need it here to modify it'. Not really the cheap solution...
    You can modify the original SC57 wheel to fit the SC59, but machining the wheel takes away strength of the wheel which is borderline stupid....
  17. megawatt
    Depends which part you machine. You still haven,t said what work needs doing? I was told a wheel wouldn,t fit my Blade, so I made adaptors for it, and it works perfectly. I am not stupid, just inventive and an engineer!!!
  18. arthurbikemad
    The rr8+ forks are 10mm closer together afaik spacers I think are the same, hub offset is the problem.. Galespeed have a spider design for the disc carrier for want of a better word and there is not much meat for the bolts taking 5mm off each side could compromise the hub, with mine there is so little meat I'd fear it could be a problem, Ive never taken the hub apart as per the engraved writing and it does look like removing it could give some alinement problems if you want to reassemble it, it's truly an odd design and unknown to me what's in it, you think not much but with near a grand a wheel Ive not had the balls to remove it...!
  19. martinowen
    Yea I would leave alone lol
  20. Dela
    Dela New Member
    Exactly. I got a mail directly from Galespeed Japan saying I certainly should refrain from taking apart the hub.
    I am an Engineer myself. I looked in to modifying the hub, but no way I was ruining the front by disassembly or taking the value out of the wheels by modifying to destruction - not to mention braking down from vmax on track with a front wheel out of balance... No.
    I didn't look into going with other discs than the original though.
