Hi there ! I've nix30 and ttx on my blade. Im' 87 Kg w/o gear. i ve made my sag yesterday : free sag 16 mm race sag 36 mm with preload max - 5 T But on end cornering, i feel the rear of my bike low. Did i take a 11 kg spring with less preload or keep the 10.5 kg and play with lenght adjuster + 3/4 mm ? For cbr and ttx owner, what spring and length are you running ?
I have 10mm free sag on the rear with 26mm rider sag, the 105 spring should be spot on for your weight fella thats why its sitting too low on the rear, add some preload on the rear and it will raise the back anyway, I would keep the ride height at the standard shock length for now, try those settings, before you change anything else
