16k service - does this list of parts and order of tasks sound about right?
Discussion in 'Maintenance' started by ccr32, Aug 21, 2015.
  1. ccr32
    ccr32 Active Member
    I've just been noting down the things I'd need to do and the parts/consumables i'd need to get if I end up performing the 16k miles valve clearance service myself rather than paying Honda or someone else upward of £450 for the privilege.
    I've put these in order I think I should do them (e.g. checking the valve clearances whilst the engine is stone cold, so before the oil change, etc.), but please shout if you think anything with this is wrong, or I am missing anything, or if there is anything else that I should also be looking at after 16k miles/2 years (note: brake fluid was done about 6 months ago, so that's fine) - fork oil maybe?
    Also to note, the checking of the exhaust headers and fitting of an APE is because there is a sort of ticking noise coming from the front of the engine, which I figure is either a leaky header or a funked CCT - thought i'd check both while the bike is in bits.
    Service list
    Parts:
    Oil filter
    Air filter
    Oil sump plug washer
    Oil
    Coolant
    Suspension pivot grease
    Exhaust header gaskets(?)
    APE cam chain tensioner
    Work:
    Remove fuel tank cover, belly fairing, side fairings
    Remove fuel tank
    Remove airbox(?) to access cam cover
    Check valve clearances
    Refit cam cover
    Fit APE cam chain tensioner
    Refit airbox
    Refit fuel tank
    Run engine - Check idle, smooth running, revs etc. for correct cam chain tension
    Drain oil
    Remove old and fit new oil filter
    Refit sump drain plug with new sump plug washer
    Fill with fresh oil
    Drain coolant
    Remove/lower radiator
    Check exhaust headers - remove and refit with new exhaust header gaskets/exhaust sealant
    Refit radiator
    Fill with fresh coolant
    Remove exhaust can
    Remove and refit suspension linkages with fresh grease
    Refit exhaust can
    Refit fuel tank
    Run engine - check oil and coolant levels and top up as necessary
    Refit fairings
  2. Iain
    Iain Active Member
    Coolant should be changed every 3 years, however brake fluid should be changed every 2 years.
    Not sure why you would want to remove the exhaust headers, but greasing the shock linkage is a good idea.
  3. scooby
    scooby Elite Member
    guessing at a 16k service,bikes tend to get a lot of crud up there so is a good idea to strip them down and check the studs/nuts etc.
    even though all that needs to be done at that mileage,i shudder to think what the labour bill for all that will come too.you'd be surprised how easy most of that is to yourself.
  4. Alblade
    Alblade God Like
    My Blade did 80k and the studs and bolts for the exhaust were never undone / checked.
    If I am correct they are a 'use once, then replace' item as don't stay tight after being undone
  5. Cbrjay
    Cbrjay Well-Known Member
    You can reuse studs and bolts as long as they not stripped or cross threaded.
    Have you got access to shims? You might get away with moving some around if you find clearance is out
  6. djmrmagic
    djmrmagic Active Member
    If your going to do all that you might as well change the plugs?
    Then you know everything is fresh :)
  7. scooby
    scooby Elite Member
    is that the same as caliper bolts?...
    never heard that myself,and tbh they are only torqued up to quite a low force so wouldn't worry about them being overly tight anyway.
  8. Alblade
    Alblade God Like
    Since my engine was replaced with new headers a couple of bolts came undone after another 11k. They were tightened up to torque but worked loose again.
    Have ordered replacement studs and bolts to prevent happening again as fair job to remove rad and fairings to access.
  9. Sax
    Sax New Member
    CCR32,
    To get the valve cover off you will have to remove the PAIR valve and associated pipe work and the radiator. There is so little space that you have to take the valve cover off over the front of the engine - it will not come out of the top between the frame.
    Other than that, your plan looks good
  10. ccr32
    ccr32 Active Member
    Thank you all for your feedback.
    Iain - thanks. Brake fluid was done at last service so no need for that for now. Coolant, figured I may as well if I was going to have to drop the radiator anyway (though that said when I did this on the CBR600 I had previously, I didn't actually have to drain the coolant).
    Exhaust headers I was going to take off and look at/refit because there is a noise which either sounds like an exhaust blow or something ticking away in the engine (hence CCT) - looking and prodding around today however, it may be as simple as a misdiagnosis from me of the location of the noise and actually the join between the centre section and end can - I've siliconed it up today so will see if that stops it before throwing more parts (or labour) at the bike!
    djmrmagic - yes, I may as well do the plugs too if doing everything else! Think service manual says only a check is required at 2 years, but replacement is not going to do much harm other than a bit of a dent to my wallet.
    Cbrjay and Sax - thanks for the tips/heads-up for the valve clearances. I am beginning to think I should shy away from this myself for now owing to not having exactly great facilities to work in and that it may take me more than just a few hours to work out how it all comes apart, and goes back together again! A well-known and respected tuning company has quoted me £150+VAT to do the check while it is in there for a dyno PCV tune, so may well just do that and all the other service items myself.
    Iain - just a thought when I was crawling under the bike today - will I need an abba stand or similar to be able to grease the shock linkage? Guessing now that I wouldn't be able to do it on a paddock stand as the swingarm will still be under load...?
    Thanks again all.
  11. N1xxl
    N1xxl Member
    Get a pair of cheapo car axle stands these will work fune under fixed footpegs to allow u to remove shock and lunkages.
  12. ccr32
    ccr32 Active Member
    Good call! I think I have some kicking about somewhere... Thanks!
