16k Service
Discussion in 'General 1000RR Discussion' started by Alan Summers, May 9, 2024.
  1. Alan Summers
    Alan Summers Active Member
    Is it worth the cost? I don't plan on selling my bike anytime soon and will surpass this milestone this year and not sure if its worth having it done or not. What have you guys done?
  2. Alan Summers
    Sorry meant to be in maintenance section
  3. Selmer50mark
    Selmer50mark God Like
    Did mine @16000 got the cover off and 3 exhaust were out of tolerance, on the tight side . Local bike mechanic charged £165 for rechecking the gaps and replacing the 3 shims and cam cover back on , I did the rest of the rebuild.
    PS everyone on here will know if you do it or not o_O
  4. Broadie
    Broadie Active Member
    It's not critical at that mileage, won't hurt to defer to the winter. Might even get a better deal at the garage when their not flat out.
  5. bonjo
    bonjo Active Member
    I did mine @16k most of the exhaust valves were too tight. Has it done by a former honda technician so the blow was slightliy cushionned.
    My theory is they are on the tight side from the factory to allow for it to open up with wear.
    If you do no thrash your engine, may be worth to wait for 32k. Just my take
  6. Broadie
    Bucket and shim will never go larger.
  7. jockmcsporran
    jockmcsporran New Member
    I did my 600RR track bike a couple of winters back as I noticed it had started to feel sluggish around 14k rpm and above. Probably 50% of the shims needed replaced. It had lost over 10% of its peak power based on before and after dynos and pulled much better afterwards.
    No idea what mileage the bike is on though as the HRC loom doesn't have a speedo sensor.
  8. Alan Summers
    Anyone know a good bike mechanic in Yorkshire?
  9. LowSide76
    LowSide76 Active Member
    I had mine done at 19k miles by parkitt racing. Think it cost abput £300 , all were in spec and didn't need adjusting.
  10. Alan Summers
    Been quoted £700 by Castle Homda
  11. Selmer50mark
    :eek::eek::eek: is that just to check the gaps and or any replacement shims
  12. edderby
    edderby Active Member
    I have had mine since new in 2009 and done over 46,000 miles and not had valves checked yet. Supplying dealer said not to bother until after 50,000 miles unless it’s tracked a lot (mine’s never been on a track and I ride it fairly gently compared to some). I do always use premium fuel (Shell Vpower normally) in the hope that it’s helping reduce valve wear. Bike runs fine
  13. Alan Summers
    The price included the check but not the shims
  14. Selmer50mark
    Find an independent mechanic, I'm sure someone can recommend one over your way . I'd check it for ya if you were local to me for half the price ;)
